@ Nikbry, is this choise for FW 1.32 a conscious choise based on some criteria that were important to you or did you just stick with it over time more like randomly?
In the first case I could decide to start with 1.32 too. If it is the latter I'd could just start with what it comes with, or even the latest one and stick with it from there.
In my mind an oscilloscope has to do at least three things correctly:
1) Display the right waveform without distortions or artifacts (sine, square, AM, FM, pulse, etc)
2) Trigger reliably
3) Display data accurately and as precisely as possible
To answer your question:
FW 1.32
1) Displays the waveform correctly, except: a) with medium/high MHz signals a jitter becomes evident b) at very low frequencies and large time bases periodic signals show a somewhat randomly appearing distortion of the wave.
2) Trigger works reliably (FW 1.38 and upwards introduced trigger HD and Peak, and corrected the jitter. This broke the trigger function, specially with fast pulses. Autorange was broken too.)
3) The measurements done by the scope are mostly inaccurate for voltages and OK for frequency and period. I suggest you use the cursors to get a better quantification. This is true for all FW versions.
Some minor problems of FW1.32 are that when you autorange with no signal, CH2 activates itself. Also when holding an image the cursor lines sometimes disappear when moving them.
With FW1.32 you miss out on: the trigger peak/HD option, the FFT function, ...
The biggest problem with my unit and @IC_Toaster's seems to be a hardware one. In my case at 10x probe setting I do have a noticeable signal attenuation in @IC Toaster's it's even more severe.
The normal behavior of the Zoyi should be to see no attenuation up to 10MHz.
If you can, get access to a reliable signal generator (and ideally a second reliable oscilloscope) and test your unit to see how it behaves.
The Zoyi firmware works just fine on an Aneng.
A good beginner's exercise with an oscilloscope is to "design" RC low pass, high pass, band filters. Here are two links:
https://www.homofaciens.de/technics-base-circuits-rc-circuit_en.htmhttps://www.electronics-tutorials.ws/filter/filter_1.html
