Author Topic: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)  (Read 602417 times)
0 Members and 24 Guests are viewing this topic.
Offline ajar171
Re: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)
« Reply #800 on: November 10, 2024, 11:58:32 am »
Hi everyone!
long time lurker here. Could not help myself and bought this instrument, although I have way too many test equipment.
The bugs are really annoying, so maybe there would be interest here, to make an open source firmware for this scopemeter?
After a quick check of the PCB, here is what I know:
MCU: STM32H7B0V <- confirmed with a JTAG ID scan
ADC: can only make out "2088", maybe MXT2088 (an AD9288 clone) <- MSPS and pinout does not really make sense here, so I am probably wrong MXT2088 it is...  >:(
SPI Flash: PY25Q128HA (confirmed via SPI readout)
DMM chip: DTM0660L
Two shift registers as port expanders: HC595
Analog switches: 4051
MCU readout protection is enabled, but SWD is still enabled, so finding an exploit to read back the internal flash should work. Voltage glitching of the ST bootloader should also be an option.
The firmware updates are encrypted, but it does not look like a proper encryption after a quick check.
Attached is a screenshot of the internal RAM content, showing the framebuffer :)
Edit: ADC confirmed
« Last Edit: November 27, 2024, 12:47:52 pm by ajar171 »
The following users thanked this post: EU1, m72, Spirex, nikbry, maxmatteo, apollo11fan
Offline ajar171
« Reply #801 on: November 10, 2024, 02:02:47 pm »
Some information on the firmware update file format (ZTK):
16 bytes header:
0 to 3: file length - 16 (header length)
4 to 7: unknown, looks like 16 bit uint (bytes 6 and 7 always 0), maybe checksum
8 to 15: always "OSC7EF91"
starting at byte 16 is the firmware
The encryption looks like taking 8 byte blocks. It is not a real block cipher as statisctical analysis reveals, that the bytes
87 D0 A9 A6 1A D6 2A 78 decrypt to 0, when they are in the position 0 to 7 or 8 to 15 respectively
Simple XOR with byte swapping did not bring any usable result
edit: my assumption above, about the block cipher is probably wrong, as the 8 bytes above almost alway appear in the exact order.
The MCU supports DES, 3DES, AES in hardware, because of the 8 byte blocks, DES and 3DES are possible candidates
« Last Edit: November 10, 2024, 04:44:10 pm by ajar171 »
Offline nikbry
« Reply #802 on: November 10, 2024, 02:10:54 pm »
16 bytes header:
The encryption looks like taking 8 byte blocks. It is not a real block cypher as statisctical analysis reveals, that the bytes
87 D0 A9 A6 1A D6 2A 78 are 0, when they are in the position 0 to 7 or 8 to 15 respectively
Thank you for trying to get the ball rolling...
Hopefully, someone can help  in getting the project gain momentum.
Sadly, I'm thoroughly ignorant and useless in all matters regarding firmware development. But if any "monkey" tasks should arise, I'd be more than happy to contribute my share.
Offline ajar171
« Reply #803 on: November 10, 2024, 03:48:33 pm »
Maybe @tv84 could take a look at the encryption of the update file :)
I have unfortunately killed my SPI programmer, so can not read the contents of the SPI flash (hopefully there is some patchable code there) until a new one arrives.
Using the original bootloader would be the easiest way to put a different firmware on this meter.
The following users thanked this post: EU1, maxmatteo
Offline spikey1973
« Reply #804 on: November 13, 2024, 02:46:08 pm »
I still have the meter here, as AE is very much not responding ont the return issue.
This is new to me, as my earlier experience has always been good to moderate, but now not so much.
Anyway, I believe I have a chip reader lying around. maybe I can help reading the SPI (with some help)
I will look into what I have later today, and make pictures / response to see if it is of any value.
Kind greats, Matthieu
Addition:
I have an:
* AVRdude compatible device, USB AVR programmer / SPI interface. (well if I can find this one)
* AVR USBASP programmer (https://stackoverflow.com/questions/16615640/using-usbasp-programmer-for-spi-communication)
* USB ISP programmer (same thing i believe, but got it with something)
https://nl.aliexpress.com/item/1289376766.html?spm=a2g0o.productlist.main.21.656e3ccak0V4NQ&algo_pvid=94913f6c-c923-434e-91e9-8da5841ae19f&algo_exp_id=94913f6c-c923-434e-91e9-8da5841ae19f-10&pdp_npi=4%40dis%21EUR%214.39%214.39%21%21%214.56%214.56%21%402103846917315105423918075e8df0%2158746620936%21sea%21NL%21706585505%21X&curPageLogUid=EDoHT7iZXxmw&utparam-url=scene%3Asearch%7Cquery_from%3A
* Bus Pirate -> this seems to me the best available option..
and a bunch of matching (flat)cables.
so if there is something here that I can use to read the SPI with your help, let me know.
« Last Edit: November 13, 2024, 03:12:13 pm by spikey1973 »
Offline apollo11fan
« Reply #805 on: November 22, 2024, 01:59:31 am »
Does anyone have any information on Zoyi's commitment to continue to release firmware updates for the 702 and 703 models? When I made an inquiry via their website, there have been nothing but crickets since.  |O
Offline indman
  • Country: by
« Reply #806 on: November 22, 2024, 07:50:47 am »
Similar to famous FNIRSI, wait for the new version of ZT-704/705 from ZOYI to appear sooner :horse:
Have you not understood the strategy of these Chinese firms - they are not interested in supporting outdated models, it is more profitable for them to produce something new and raw! :D
« Last Edit: November 22, 2024, 07:55:47 am by indman »
The following users thanked this post: m72, apollo11fan
Offline apollo11fan
« Reply #807 on: November 22, 2024, 09:05:54 am »
This is apparent. Sad. Wasn't the ANENG hardware the same? Maybe they've produced a new version of the firmware that's compatible?
Offline IAmBack
Another bug in the meter...
« Reply #808 on: November 22, 2024, 12:05:59 pm »
For time base slower than 100 ms (it means 200ms +) triggering mode can be only set to auto.
Pity, as slow tb is useful with single mode.
Offline xKertx
« Reply #809 on: November 25, 2024, 11:05:38 am »
Really?
There has been several updates, released approximately every 2-3 months.
Offline Atlan
  • Country: sk
« Reply #810 on: November 25, 2024, 04:15:05 pm »
Nice, but not working corectly :D
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Firmware is here (or not) https://github.com/Atlan4/Fnirsi1013D/tree/main/Guide%20to%20firmware
Offline spikey1973
« Reply #811 on: November 25, 2024, 08:54:55 pm »
Hello to all,
As mentioned before, I had decided on sending my 703 back under the free return clause.
Unfortunately AE or the seller were being difficult and did not agree. Anyway..
The end of the story is that I have received a refund for the majority and didn't need te send it back, so I agreed
I unpacked it again and started fiddling with it this evening and I bumped into an issue I bumped into before but I believe it is nothing I have not read about here.
The issue is the signal-generator menu under F1.
The menu under F4, works, I can do anything there and it works.
Under F1, I can change everything but non of the changes seem to stick/have an effect.
That includes the turning off of the signal generator. I can not seem to turn it off.
In F1 I put it on "off", but when Exit it is still on, does anyone else have this issue with FW 1.4.2?
and or / Is there any different way to turn the signal gen off?
(I did read the manual, to see it there in a not-so-intuitive manner, but it seems like I did it all as should)
So currrently I am planning to flash the firmware but am not sure which version to choose for.
If it not an issue that is common I can try to reflash 1.4.2. but I can also for an older one. 1.3.2 / 1.3.8 / 1.3.9 .The latter one is a version I haven't read much on besides it being slow. and I read that 1.3.8  allready has the bad auto range. but I also believe that most people here still use. 1.3.8, but I could be wrong.
1 have read positive comment on both 1.3.8 and 1.3.2. but am not sure if there is any consensus on which would be the least bad of these two.
The only thing I know is that @nikbry seems to stick to 1.32. but it also seems like most still use 1.38.
At least untill they create the superb FW version.. if it will ever comes (sure hope so).
Anyway, thoughts are appreciated.
Additionally is there still links to either version 1.32 and 1.38
« Last Edit: November 25, 2024, 09:55:09 pm by spikey1973 »
Offline chebo
« Reply #812 on: November 26, 2024, 07:35:03 am »
ZT-703S, FW1.39 (last). The error with determining the minimum and maximum values ​​has not been fixed.
A little experiment. I generate the input pulse manually from the power supply. The voltmeter BM789 is in the Crest mode (we will check this mode at the same time).
2446537-0 2446541-1 2446545-2
Experience is what we got instead of what we wanted...
Offline suntide
  • Country: cn
« Reply #813 on: November 26, 2024, 08:31:01 am »
I found this, it seems a firmware bug. Press “Default" and confirm, it will close the signal-generator output.
The following users thanked this post: spikey1973
Offline xKertx
« Reply #814 on: November 26, 2024, 10:20:09 am »
(Attachment Link) (Attachment Link) (Attachment Link)
Latest FW is 1.42
Offline chebo
« Reply #815 on: November 26, 2024, 10:43:17 am »
Latest FW is 1.42
Oh! You are right! I'll download, install and double-check.
« Last Edit: November 26, 2024, 10:46:44 am by chebo »
Offline spikey1973
« Reply #816 on: November 26, 2024, 05:47:48 pm »
I have searched throught the thread, but didn't find a download link for either of them, I believe I prefer 1.32 but wpuld love to have them both.
Does anyone have the fila available (preferrably with a checksum to make sure the file is oke after the download. )
Kind greats
Matthieu
Offline indman
  • Country: by
« Reply #817 on: November 26, 2024, 05:54:31 pm »
You were looking poorly or in the wrong place. Here is the link on page 20 of this topic
https://www.eevblog.com/forum/testgear/new-zoyi-multimeteroscilloscopes-zt-70xs-up-to-50mhz250msps-(nov-2022)/msg5585305/#msg5585305
Offline chebo
« Reply #818 on: November 27, 2024, 07:28:55 am »
Latest FW is 1.42
I have installed the latest version of the software.
2447093-0
But I wouldn't say that anything has changed much.
2447097-1 2447101-2
Offline csuhi17
  • Country: hu
« Reply #819 on: November 27, 2024, 08:43:56 am »
It only doesn't work with Single trigger?
Does it measure well in Normal and Auto mode?
Fnirsi oscilloscope = waste&regret
or maybe I was wrong
Offline ajar171
« Reply #820 on: November 27, 2024, 09:13:34 am »
Finally I had time to investigate further into this scopemeter.
First of all, the SPI flash is only used for data storage (mass storage USB mode), nothing of value is on it. They did not even bother to connect it via quad-SPI...
My assumption about the ADC being an MXT2088 (AD9288 clone) seems to be correct. All the signals measured are located there, where they should be according to the datasheet.
So this scopemeter has only 100MSPS in normal mode (verified the 100MHz clock on the ENC pins with a real scope :) ), the high speed mode is overclocking the ADC to 140MHz (MCU fmax/2)
I was wondering the whole time, how they got the advertised amount of data into an MCU with an fmax of 280MHz without using an FPGA. Well they did not... It is probably even sampling the two channels alternating, but did not bother to check this, as the 100MSPS is already a dealbreaker for me (bought it for measuring high-ish speed RS485 comms waveforms in the field)
Just another datapoint: when running at 100MSPS, the ADC is running 100 times a second with 100MHz bursts, so max 100 wafeforms/s, if the sampling is alternating, then 50 wfrms/s.
If there is interest, we could still make an open source firmware from scratch for this meter, but nobody knows how long this meter will be on the market. As already mentioned here, chinese manufacturers are quick to abandon products...
Since there are no magic tricks used to get 280MSPS / channel of data into the MCU here, I dont really care about the stock firmware anymore, and the PCB is simple enough to reverse...
Triggering is also only in software. With the low waveform/s count, I could set up the scopemeter with an AWG in a way it never triggered. I guess I got, what I paid for.
Edit: high speed mode clock measured
« Last Edit: November 27, 2024, 01:05:49 pm by ajar171 »
Offline koks1960
  • Country: ru
« Reply #821 on: November 27, 2024, 02:19:03 pm »
This device is made according to the ARM+ADC scheme, whereas most other manufacturers use the FPGA+ARM+ADC scheme. Therefore, this device does not work well. And the new firmware won't do anything.
Offline ajar171
« Reply #822 on: November 27, 2024, 02:30:41 pm »
Exactly.
It could be made better, but it will never be a proper oscilloscope.
The only question is, it worth the time, to make a proper firmware for this device, or just wait for a scopemeter with at least an FPGA in it  :-//
« Last Edit: November 27, 2024, 02:32:48 pm by ajar171 »
Offline chebo
« Reply #823 on: November 27, 2024, 02:37:41 pm »
What compact proper oscilloscope would you recommend?
Offline black6host
« Reply #824 on: November 27, 2024, 02:42:41 pm »
I just picked up a Zeeweii dso3d12 scope/meter.  I'm liking it so far but I'm afraid I'm too new to scopes to put it through it's paces.  Maybe something to look at?
Edit:  From the specs it appears the Zeeweii is a better scope.  The Zoyi is the better DMM.  Again, from the specs.  I've not tested the two in practice yet...
« Last Edit: November 27, 2024, 02:44:41 pm by black6host »
