Author Topic: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)  (Read 546021 times)
0 Members and 11 Guests are viewing this topic.
Offline OLderDan
both the more apps and external work over all ranges and signal types, checked with the z703s and my dso2d15. I haven't checked since upgading and downgrading the firmware, but I have no reason to believe anything has changed.
Offline Phb
  • Country: my
Same "glitch" in my case.
Have you check if the signal generator really works?
Not for me, You can see may last post and the video
Would you be able to get a warranty claim from whoever you purchased it from?
Alternatively, you can try the information here to have your issue resolved.
http://www.szzotek.com/h-col-160.html
Its a mandarin based page, but you can use translate to access it. And the WeChat link seems interesting, although I have never tried it. The shipping from where you are from may not be be financially viable though.
Offline fortis
  • Country: ru
Just made a new probe cover with a thinner bottom to fit standard connectors
https://www.thingiverse.com/thing:7053840
« Last Edit: June 01, 2025, 07:55:30 pm by fortis »
The following users thanked this post: kd7eir, m72, OLderDan, zrejec
Offline rx485
  • Country: ru
Hi! I bought myself a ZT-703S. After 2 months of use, I noticed that the oscilloscope on channel 1 with the probe disconnected began to underestimate at x1 by 300 mV, and at x10 by about 3 V. When applying a signal, the signal shifts by 300 mV down along the y axis. The built-in calibrator does not help. I also tried to flash it to the previous firmware, the problem remained. Maybe someone has encountered such a problem.
« Last Edit: June 13, 2025, 06:59:36 am by rx485 »
Offline Phb
  • Country: my
........ channel 1 with the probe disconnected began to underestimate at x1 by 300 mV, and at x10 by about 3 V. When applying a signal, the signal shifts by 300 mV down along the y axis.
Have you tried the "Default" option and then the "Calibrate" (with probes disconnected) menu buttons?
As per the pict below?
Offline rx485
  • Country: ru
Hi! Yes, I tried it, the calibration function showed calibration failure. I think I fed too much signal to the oscilloscope and didn't even notice, which led to this signal distortion. I'm on a business trip now and I don't have the opportunity to disassemble the 703 to make sure the amplifier circuits are working properly. I'll come back in a couple of days and look into this problem more thoroughly.
« Last Edit: June 13, 2025, 11:40:30 am by rx485 »
Offline mebel
https://drive.google.com/file/d/1did2_dDTP_rK_eO7O9-joANWN-guBZ_P/view
V157 Version Upgrade details:
1.Update: Fixed the triggering issue at 250ns
Offline MiroS
Are you located close to transmitter jamming GPS signal ?
The following users thanked this post: PerranOak
Offline 008nothing
  • Country: gr
Hello, recently i tried using the zt-703 to read a dual signal waveform (don't know if that's the correct term) but obviously it didn't work. Our work scope did read both waveforms in a single channel easily as you can see in the attached photos. It there a way that i could make the zt-703 do that or is it a hardware issue?
« Last Edit: June 21, 2025, 08:53:08 am by 008nothing »
Offline Aldo22
How do you create such a waveform on one channel?
Offline 008nothing
  • Country: gr
To be totally honest i am not sure ,we have to take some measurements and chance the capacitance of the circuit to try to ,among other things, align the 2 waveforms but i have no idea how they are generated as i am pretty new to this job and i am just learning the basics for now
« Last Edit: June 21, 2025, 10:30:44 am by 008nothing »
Offline kloetpatra
This has nothing to do with ZT-703. Also your second picture is so bad that you can't even read anything. How do you think someone in particular can help.
This is oscilloscope basics and is related to sample rate and waveform update rate.
If the time base setting is faster, the acquisition rate is faster than the screen is able to display. Then several acquisitions are overlayed and displayed at the same time. The behaviour will vary between different oscilloscope models. There are possibilities that prevent that:
- using the "Single" mode
- choosing a slower time base
- using the "trigger hold off" function to reduce the acqusition rate
Offline 008nothing
  • Country: gr
I saw it when i went to post it but i don't have another picture and don't know when i'll get the chance to take another one. but what i wanted to show was that with the same signal one was showing one waveform while the other 2 waveforms. The desired result for me in this instance it to get 2 waveforms to show .And i am wandering if that is possible with the zt-703. The signal usually is in the range of 5-17Khz) and the voltage from some mV to 10V. Currently the waveform seems to go back and forth the 2 and seems unstable.
« Last Edit: June 21, 2025, 11:50:08 am by 008nothing »
Offline Aldo22
If the two waveforms are “real”, then measure them with both channels. If not, what do you want to do with that?
Normally, two signals on one channel add up as in the screenshot below (magenta).
« Last Edit: June 21, 2025, 04:58:02 pm by Aldo22 »
Offline kloetpatra
No, you will never have the ZT-703 showing this modulated waveform like the Fluke 190-202. You can use the "persist" function to overlay multiple waveforms. Compared to the $5000 Fluke the ZT-703 is a toy and still has many bugs. However, your observation is not a bug, rather a limitation of the hardware and the way they implemented the waveform display.
sounds like an asynchronous triggering problem which is totally normal for such kind of signal.
The following users thanked this post: 008nothing
Offline 008nothing
  • Country: gr
Thank you, makes sense that those limitations exist in this price point, i was just making sure as i can't really understand how the fluke even does 2 signals in one channel work without them getting added to each other (like the person above suggests).
Offline Aldo22
I'm beginning to understand.  :-//
kloetpatra is right, this is a modulated waveform.
The Zeeweii DSO2512g can display something like that.
It depends on where the trigger is set.
With a stop, of course, you only see a single trace.
On the DSO2512g you don't need to activate persistence for this.
But I'm still not quite sure what that's good for.
@008nothing: Is that what you are looking for?
« Last Edit: June 22, 2025, 10:59:47 am by Aldo22 »
Offline 008nothing
  • Country: gr
yup, i think that's what i was going for. Mostly out of curiosity as at work we have to use the fluke ones because of certifications e.t.c.
Offline Aldo22
OK, but I suspect this is still some kind of triggering artifact.
The signal probably looks more like the attached screenshot (magenta). That's 17kHz and 5kHz added together.
Offline mebel
Anybody knows if custom firmware project is dead?
The following users thanked this post: Markus2801A
Offline Edmiri
  • Country: al
I hope not.
Offline rx485
  • Country: ru
Hello! Can you tell me the marking of these two components on the first input of the Zoyi ZT-703? 1: 8091 is ad8091, 2 is TVS diode? Did I understand correctly?
« Last Edit: July 10, 2025, 03:36:33 pm by rx485 »
Offline PerranOak
When they update the firmware do they update the manual, e.g. use of FFT?
You can release yourself but the only way to go is down!
RJD
Offline eljjc
Re: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)
« Reply #1298 on: August 06, 2025, 08:35:51 pm »
I haven’t seen any updated manual for the ZT-703S corresponding to recent firmware updates.
Regarding the FFT feature: from what I’ve observed, the X-axis (frequency scale) seems to be tied directly to the selected timebase. For example, if you set the timebase to 20 µs/div, the FFT X-axis corresponds to 50 kHz/div. So the frequency range displayed changes depending on your timebase setting.
As for the Y-axis, it looks like they normalize the highest peak rather than displaying an absolute amplitude scale. So it’s more useful for identifying frequency components than for precise amplitude measurements.
Hope that helps!
The following users thanked this post: PerranOak, m72, OLderDan
Offline kloetpatra
« Reply #1299 on: August 14, 2025, 07:38:00 pm »
I don't know why nobody mentioned it in this thread yet, but Zoyi used the wrong charge controller ME4086B which has charge termination at 4.35V. Correct 4.2V one would be ME4086A. Zoyi should definitely do a recall before they put houses on fire.
I wonder if newer devices use the correct one?
Big thanks to @BRN who found this issue. Definitely check out his thread: https://www.eevblog.com/forum/testgear/zoyi-zotek-zt-703s-fire-hazard-while-charging/
« Last Edit: August 14, 2025, 07:41:20 pm by kloetpatra »
The following users thanked this post: ddrl46, kd7eir
