Author Topic: NICE-POWER Programmable DC Power Supply 30v 10a  (Read 1480 times)
Offline jimbo493Topic starter
« on: August 14, 2023, 03:00:28 am »
Hey all,
I was curious if anyone has used these power supplies before? https://www.amazon.com/NICE-POWER-Programmable-Precision-Adjustable-Regulated/dp/B0C686ZYPF/ref=sr_1_5?keywords=Programmable%2BPower%2BSupply&qid=1691978853&sr=8-5&th=1
I am looking for something cheap and PC controllable, ideally with a hackable protocol so I can integrate into a different program. I am hoping to make a test box for pixel addressable LEDs that would also have a pixel controller, you could choose the pixel type and then it would send a voltage and current limit to the PSU, rather than having to look it up and dial it in. 30v 10a seems like the ideal size since I deal with LED tape ranging from 5-24 volts, and spools rarely consume more than 4-5amps.
If you have any other ideas in the sub $100 price range let me know. Ideally something that has been hacked before/has a documented protocol. I did order the one linked above, mostly so I can see if the protocol is usable.
