Author Topic: Racal Dana 9914  (Read 7075 times)
Offline FlumpTopic starter
Racal Dana 9914
« on: June 19, 2014, 10:43:06 am »
Has anyone had any experience of this frequency counter
good or bad ?
I just bought one as my current optoelectonics handy counter 2810
can drift up to 10 Hz from day to day and I am hoping the 9914
will be better.
Offline grumpydoc
Re: Racal Dana 9914
« Reply #1 on: June 19, 2014, 01:34:33 pm »
The stability will depend on which oscillator it has in it. Best is 04E, then 04B which are ovened. I'm sure the 99xx series had an option for a plain xtal oscillator - 04C I think - which you would want to avoid unless you intended to run it with an external standard.
Note the external standard input on these was 1MHz, not 10MHz which is usual on more modern equipment.
These rely on an unobtanium counter chip custom built by Ferranti so make sure you see it working.
Re: Racal Dana 9914
« Reply #2 on: June 19, 2014, 08:47:06 pm »
thanks very much for the info doc   :-+
I bought it because A it was cheap and B it had to be better than my current counter.
Okay so it looks like it has a standard Xtal oscillator,
would the 1Mhz check reading on the display be a good indication if the crystal is is ok and accurate  ?
or are there other tests I can do to determine if it needs to be upgraded ?.
I found this on ebay, would this be a good upgrade for it ?
http://www.ebay.co.uk/itm/PRECISION-1PPM-1-000MHz-TCXO-/380174345926?pt=LH_DefaultDomain_0&hash=item58842826c6
I am not sure about the external standard input, I will do some googling on that
Any more info / advice anyone can share I would appreciate it.
Here are a few pictures of it.
Online Andy Watson
Re: Racal Dana 9914
« Reply #3 on: June 19, 2014, 09:04:12 pm »
Unlikely. The 1 MHz check is almost certainly a check of functionality of the counting circuits. It tells you that the crystal oscillator is functioning but not what frequency it is running at (it is checking itself against itself). If you have an oscillator and a longwave radio you could beat that oscillator against BBC radio 4 on 198kHz. you should be able to get within 1Hz with relative ease, this will give you a rough check of the accuracy.
I have two Racals, their long term stability is excellent, but, the OCXO can take up to 40 minutes to warm up from cold before it is on-song.
Online Vgkid
Re: Racal Dana 9914
« Reply #4 on: June 19, 2014, 09:05:33 pm »
You could grab a 10 Mhz ocxo and throw it through a ls90 to get your 1Mhz.
Re: Racal Dana 9914
« Reply #5 on: June 19, 2014, 11:28:30 pm »
I would love to vgkid, if i knew how  :-DD
Online Andy Watson
Re: Racal Dana 9914
« Reply #6 on: June 19, 2014, 11:40:05 pm »
Substitute 74ls90 for ls 90 and see if that gets you anywhere ;)
Re: Racal Dana 9914
« Reply #7 on: June 20, 2014, 01:23:29 am »
Thanks Andy
I found the datasheet for it but there are no examples of how to wire it up,
I looked on google too and cant find one.
I feel like such a noob sometimes  :palm:
Atleast those chips are quite cheap at £2.93 on uk ebay
Online Vgkid
Re: Racal Dana 9914
« Reply #8 on: June 20, 2014, 02:38:00 am »
It is from the Fluke 1952 counter manual, only 1 LS90 is needed.
Look at the bottom of the page, U3/U4/U5
actually, here is a better example
http://circuit-diagram.hqew.net/Frequency-Divider-For-Measurements-Circuit_17100.html
« Last Edit: June 21, 2014, 03:51:04 am by Vgkid »
Re: Racal Dana 9914
« Reply #9 on: June 21, 2014, 04:07:40 pm »
thanks for the diagrams vg kid  :-+
I have ordered 1 of these and it should be here soon
http://www.ebay.co.uk/itm/390699562045?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
To be honest I still dont understand how to get the 10mhz to 1mhz using 1 chip as i dont understand
the datasheet fully, but I am looking forward to playing around with it to see if I can work it out :)
Offline babysitter
  • pushing silicon at work
Re: Racal Dana 9914
« Reply #10 on: June 23, 2014, 08:22:29 am »
Hi Flump,
these are logic ICs which contain some dividers. First page of your PDF  explains what you need to do:
A symmetri-
cal divide-by-ten count can be obtained from the
DM74LS90 counters by connecting the QD output to the A
input and applying the input count to the B input which
gives a divide-by-ten square wave at output QA.
To-do: Turn your 10 MHz sine from OCXO into a logic level signal (TLL, as rectangularish as possible, anything which goes belov 0.8V and above 2V is sufficient. This signal should go into input B of the 74LS90, on QA comes the 1 MHz Signal, also a 5V logic signal but with 1 MHz.
Clip, attenuate, higpass filter the output until it fits the requirements of your counters reference input.
Alternative pathway, you might consider buying a QH40A xtal heater from Kuhne electronics (DB6NT, around 12€) to temperature-stabilize your internal references xtal, and check if it is already more stable. If the internal reference  has a trimmer for adjustment you might consider reducing the trimming range.
I'm not a feature, I'm a bug! ARC DG3HDA
Re: Racal Dana 9914
« Reply #11 on: June 23, 2014, 11:33:31 am »
Hendrik to the rescue again!
How on earth did i miss that in the PDF  :palm:
I am really looking forward to having a play with that chip now,
still waiting for the mail to arrive but i'm hoping it might come today.
Never heard of those crystal heaters before, they are a great product
and added to my bookmarks incase i need them in the future.
I don't really want to change anything inside the counter so I think
I will use an external reference first and see how that goes.
 :clap:
