Is this important? I can capture all the pins above at once with the scope or the Saleae if you need to know what threy're doing, but maybe I should focus on the other bits in TSO?
So the "Theory of Operation" section of the service manual has this to say:
Trigger and Sweep Activity (Status)
The activity of the Trigger and Sweep circuits, as indicated by the /SGA, /SGB, /TSA, and /TSB lines, is reported to the Microprocessor via the TSO (trigger status output) line when clocked by the TSS (trigger status strobe) signal.
So /TSA and /TSB are inputs to the Display Sequencer, and not outputs from it, as I had surmised. Presumably these four account for 4 bits of the TSS, with the a fifth bit being the "not single sequence underways".
I'm not sure that this is important, though I suspect it might be necessary to understand this in due course for the emulator to pass the 05 tests.
Mkay, I think this is simply a really fast auto sweep. I'm still trying to figure out how auto sweep works, though by diffing the register settings for the same sweep in AUTO vs NORM I see this:
diff AUTO.txt NORM.txt
35,37c35,37
< :trig_a: 0xFA
< -TM0-1, Not Trigger Mode: 1(FAST_COMPARE)
< -FR, Not Free Run, Continuous Trigger Gate: 0
> :trig_a: 0xFF
> -TM0-1, Not Trigger Mode: 3(SWEEP)
> -FR, Not Free Run, Continuous Trigger Gate: 1
44,45d43
So in other words, AUTO is FAST_COMPARE mode with the continuous trigger gate, whereas NORM is SWEEP mode with no continuous trigger gate.
I guess in FAST_COMPARE, the sweep triggers on the first of /TGA|/TRIG or THO - or maybe the sweep triggers on the falling edge of THO on auto sweep?
