Author Topic: Victor 4080 LCR meter  (Read 564 times)
Offline lordium
  • Country: cn
« on: March 14, 2019, 06:25:21 am »
Victor 4080 LCR meter, bought for about 100$. Had it for a while (about a year) and just though I'd write a short summary of it.
I use it mainly to check unknown/unmarked caps and inductors, but also for troubleshooting broken electronics.
Has rechargeable battery inside (use mini-USB connector). Came with 2 banana to crocodile clips, and they work for the most part, but struggle at certain values/frequencies. Has option to plug 4 wire connection, which I made using a 2 sided copper PCB (just filed away the copper between connectors and soldered cables to it). Yes it is a shitty cable but results show they work just fine (has since made a new and improved cable).
Opened it up and took a few pictures (sorry for the bad quality).
Measured it against a recently calibrated Hioki IM3523 at work, and the results were not bad (see Libre Office file).
Small portion of test for lazy people:
1.5mF, 100Hz
LCR METER       Cs      Rs Ω      D
Hioki IM3523(4w)   1.455   0.05585   0.051
Vc4080 (2w)      1.457   0.0565   0.052
I'm happy with the buy and it still works fine after having it for about 1 year.
If anyone want any other/more information about it just ask.
Offline ebclr
Re: Victor 4080 LCR meter
« Reply #1 on: March 14, 2019, 07:08:50 pm »
I also have this meter  bought from https://www.impac.com.br/medidor-esr/medidor-de-esr-com-ponte-rlc-1khz-10khz-40khz-100khz-usb.html   and I'm very happy, all my esr needs where covered
Offline soldar
« Reply #2 on: March 14, 2019, 10:55:30 pm »
I have the Victor VC9805A+ which I bought some years ago in China very cheaply and it works well for me although I do not use it intensively.
Specification:
DC Voltage:
200mV/2V/20V/200V +-(0.5%+5)
1000V +-(1.0%+10)
AC Voltage:
200mV/2V/20V/200V +-(0.8%+5) 750V +-(1.2%+10)
DC Current:
2mA/20mA +-(0.8%+10) 200mA +-(1.2%+8) 20A +-(2.0%+5)
AC Current:
2mA/20mA +-(1.0%+15)
200mA +-(2.0%+5) 20A +-(3.0%+10)
Resistance:
200Ω +-(0.8%+5)
2kΩ/20kΩ/200kΩ/2MΩ +-(0.8%+3) 20MΩ +-(1.0%+25) 200MΩ +-[5.0%(reading-10)+30]
Capacitance: 20nF/200nF/2uF/20uF ¡À(2.5%+20) 200uF ¡À(5.0%+10)
Inductance: 2mH/20mH/200mH/2H/20H ¡À(2.5%+30)
Frequency:200kHz ¡À(3.0%+18)
Celsius:(-20~1000)C ¡À(1.0%+5) Fahrenheit: (0~1832)F ¡À(0.75%+5)
Features:
Diod Transistor test
Continuity buzzer
Low battery indication
Data hold
Auto power off
Backlight
Function protection
Shockproof protection
Input impedance:10 MΩ
Sampling rate:3 times/s
AC Frequency response:40~400Hz
Manual range
Max. Display:1999
LCD size:70x50mm
Standard Accessories:
Test leads
Instruction manual
TP01 temperature probe
