Author Topic: OHR Multifunction Process calibrators [OHR-C03]  (Read 357 times)
Offline DaneLawTopic starter
« on: December 29, 2024, 09:10:56 pm »
Has anybody tried these multifunction process calibrators from OHR?
Looks to be from a Chinese company called Hongrun Precision Instrument Co. that seems to be making various displays, thermostat PID controllers, isolators, temperature-pucks etc for for the industrial market, so more or less the same product-segment where these process calibrators are intended.
OHR-A03 seems to have the highest tolerances with a peak at 0.01% while OHR-C03 seems to be the most feature-rich, but peaks at 0.03%
OHR-A03 & OHR-C03
Purchased one a few months back, [OHR-C03] the unit that got graphical display & more features.
Tried to purchase it from the company, and even though they would gladly sell at very attractive domestic CN prices, but all foreign sales, they wouldn't only to domestic addresses. had to rely on a third-party seller, who tends to put quite a mockup on these regional items.
It does give you control down to a microvolt, but it does take quite a few minutes from boot before it centers at 0µV, it will also do minus.
Got three voltage sources ranges 110mV, 12V and 24V.
110mV range.
Org English manual attached with tolerances.
« Last Edit: December 29, 2024, 10:22:59 pm by DaneLaw »
Offline danno_cj
Re: OHR Multifunction Process calibrators [OHR-C03]
« Reply #1 on: December 30, 2024, 10:16:37 am »
The only feature that OHR-C03 has over LB02A is the graph on the screen. Outgoing signals have a bit higher precision on LB02A and the price is almost half. The other one is better but also several times more expensive compared with LB02A.
« Reply #2 on: December 30, 2024, 12:18:21 pm »
Its night and day, but you can check the manual for some of the details..(posted above)
If you just want a cheap calibrator with also tons of programming features .. SG003A from Fnirsi is also a decent choice.. its the best bang for the buck.. can be had for around 45 bucks and would personally prefer that over the LB02A that is a dated unit on so many aspects that I value, but it likely comes down to many of the things I tend to use these devices for. https://www.eevblog.com/forum/testgear/fnirsi-sg-003a-sg-004a-signal-generators/msg5714555/#msg5714555
But there is a lot of these no-name devices.. you can get them for as little as 15 bucks if you want the cheapest.
These units  above is a from a maker that specialize in making these industrial controllers that relies on these testdevices..
Offline danno_cj
« Reply #3 on: December 30, 2024, 01:29:26 pm »
On current and voltage source LB02A have 0.025% and OHR-C03 have 0.05% accuracy. To my eyes LB02A is more precise tool compared to OHR-C03. Also the are many tests on YouTube regarding LB02A and those conclusions is: accuracy is spot on. There is no independent test about OHR-C03. Since you have this device make one, show us what are good features and bad aspects. When you are dealing with microvolts you also need very high precision. Higher resolution don't bring higher accuracy.
Don't compare Fnirsi devices with anything because almost all appear to be toys.
Off topic: don't quote my post since no one wrote something between our posts. Is not needed.
« Reply #4 on: December 30, 2024, 10:52:14 pm »
I quote what I want in this thread.. particularly with certain characters.
And it goes without saying' if you like your LB02A or even the 15$ LB02G or some of the other cheap variants that are on the Chinese fleamarket (in bulk) then kudos to that, but for my use cases, it simply wont do.. Way to limited (dated if you will) with its two sockets, ltd display alongside a MicroUSB, and won't do the things that I tend to use these devices for.
So it simply isn't an alternative... Its an old model, that most people are familiar with.
All these extremely cheap LBxxx models or perhaps clones that are pouring out of China or even the cheap process calibrators that come in a DMM form-factor like Mustool or TOOLTOP ET72.. Are likely good value for some, not least in lack of better, but as I emphasized, I would take a Fnirsi SG00xA, not least the SG004A any day of the week over these relatively dated 2 sockets variants and models that look more like these older mash-up Fnirsi products from the past - than the current Fnirsi variants of SG003A / SG004A and you will also get higher peak-tolerances with a Fnirsi SG004A than this LB02A you seem to have, not least if you take all their specs on face value.
As explained its night an day, on the possibilities, but you can look that up on your own behalf, or check the details in the other thread, and please drop this childish behavior "Fnirsi is a toy", with an underlying narrative that my cheap Chinese LB02A ain't.
They are all toys... though for the end-user that gets a meaningful use out of it - Its a useful tool that likely matches that person's budget and fascinating to see such precision at these relatively low prices.
« Reply #5 on: December 30, 2024, 10:55:06 pm »
For your "independent reviews" of these OHR-A03 (0.01%) & OHR-C03 (0.03%) your best bet, is to surf the Chinese forums.. it ain't models that OHR seems to have any interest in porting to the Western world or any third-party Amazon stores that will grease western influencers with freebies in exchange to dump them on western consumers like we see on YT from time to time.
OHR seems to mainly prioritize the industrial segment.
There are tons of Chinese test devices that we simply don't see here on the western market' so you have to do your homework - some due diligence efforts.. and often you simply cant find info on these foreign items, but there is also a joy in trying out new devices that haven't already been analyzed five ways to Sunday.
I personally like going down these rabbit holes and finding test-devices that I haven't seen before and cant find any user feedback or YT videos, but that's me... I get that many want some assurance, and maybe prefer that other people can vouche or that some social media influencers can guide them, before taking the plunge.
These models from OHR-is jacked with features...and why they have 5 banana sockets, alongside TypeC and USB3-A, that seem to be used for compensation (int/custom/ext)  it also came with a small thumbstick, that looks like a USB thumb drive, with a USB-3 interface, and written ext cold junction compensation.
On this "03"-model it also refers to.
Recording function, RS485 function, HART function, TTL function, Bluetooth function, AC measurement..but to what extent.. don't know yet.
Many of these aspects, are optional features where you need to go pretty far up the price ladder on high-end models to acquire, so it's really not apples to apples with these 2 sockets LBxxx models with MicroUSB, which can be had as low as 15$ for some of the variants (LB02G)
Alongside you have minus, microvolt tolerances down 1uV entry sensitivity, 1A measurement ablelity (if I recall) and also way higher resistance and frequency ability than fx LB02A, and you can program various aspects of these things, and features that seems to be common on the more adv process multifunction signal process calibrators and having waveform ability for both source & measure.. its a pleasure to visualize signals, not least relative fast moving signals or variables over long time.. you can adjust the graph on its acquisition time from 00.1s to 60.0..
Havent seen any menu so far about end-user calibration, but then again I don't have the reference source tools to deliver finer tolerances or even validate some of these specs with any meaningful certainty.
As mentioned it takes quite a few minutes before it finally settles down at 0uV.. it will start at around -6 to 8uV and then slowly center... it takes a long time before it reaches 0uV. like 10 to 20 minutes but could be the norm when dealing with such minute values.
« Last Edit: December 31, 2024, 04:55:46 am by DaneLaw »
