Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Rigol DS2072A option unlock
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Rigol DS2072A option unlock (Read 3777 times)
mmaseda
Contributor
Country:
on:
May 11, 2018, 08:15:40 pm »
I know there are a lot of old post out there but can someone please direct me to the procedure for a DS2072A using firmware revision 00.03.05.03.03
Logged
Adrian_Arg.
Frequent Contributor
Country:
Re: Rigol DS2072A option unlock
Reply #1 on:
May 11, 2018, 08:20:28 pm »
http://gotroot.ca/rigol/riglol/
Logged
mmaseda
Contributor
Country:
Reply #2 on:
May 11, 2018, 08:28:19 pm »
Already tried that but it didn’t work.
Logged
CustomEngineerer
Country:
Reply #3 on:
May 11, 2018, 09:10:19 pm »
https://www.eevblog.com/forum/testgear/unlockinghacking-the-rigol-ds2000a-series-scope-the-short-post/
This is the most recent procedure, it literally hasn't changed in years.
Logged
mmaseda
mmaseda
Contributor
Country:
Reply #4 on:
May 11, 2018, 09:58:49 pm »
When I run rigup against the dumpfile it says Failed, no keys. Using rigup for Windows 0.4.2
Last Edit: May 11, 2018, 10:25:19 pm by mmaseda
Logged
mmaseda
Contributor
Country:
Reply #5 on:
May 11, 2018, 10:49:34 pm »
Problem solved. Had to use rigup 0.4. Now have keys, Let’s see if they work !!
Logged
mmaseda
Contributor
Country:
Reply #6 on:
May 11, 2018, 11:05:53 pm »
WORKING !!!
Logged
Gazza2
Contributor
Country:
Reply #7 on:
May 14, 2018, 07:59:11 am »
How did you get it to work? I've been trying for quite a while to get the codes from my ds2072a with firmware 00.03.05.SP1 and hardware 2.3. I get the no keys message with rigup 0.4
Logged
mmaseda
Contributor
Country:
Reply #8 on:
May 14, 2018, 02:58:20 pm »
PM sent
Logged
Gazza2
Contributor
Country:
Reply #9 on:
May 16, 2018, 03:15:23 am »
Finally got mine to work! The missing piece of the puzzle was the correct scpi command :SYST:UTIL:READ? 1,33554432 to give a 32mb dump instead of the 1024kb ones I was getting, I found here
http://www.anderswallin.net/2015/12/rigol-ds2072a-upgrade/
I must have mistyped the command before because it wasn't working, so I copy/pasted it to get a successful dump.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
