I have an 1104X-E which mostly works great. However since a lot of what I do involves looking at low level signals I have a constant problem with this instrument- Pretty much whenever The DUT is grounded I have a high broad noise floor that messes with any trace below several volts. I did some careful checking and I'm getting about 25 mV of 50 KHz spikes between the scope ground and everything on my bench. Is this switching supply leakage? Does anyone else have this issue? Any advice would be appreciated.
