Inverse assembly? How many designs with an external memory bus are you going to troubleshoot with this kind of device?
Since you can gang a few of these together i was hoping to hook ten or so together to probe a 80486 running at 100MHz and follow the boot process
Here is a simple, stupid test case.
Teka an i2c bus. 5 volt 400khz.' Old skool'
Please analyser : trigger on a missing acknowledge. Any missing acknowledge.
See if it can do that.
The trigger script is easy :
If scl=1 and falling(sda) then arm
If armed : count 8 falling edges of scl then check sda. If low : trigger.
This is a trivial task that even the cheapest onehung low logic oscilloscopes can do.
None of streamers can cope with that.
These things are toys. You can frequently pick up a big iron analyser for a few 100$. I got a 16900 for 200$ ... When i get back i will post a teardown of a real analyser. It'l become painfully obvious then that these usb boxes are not worthy of the name analyser.
