Hey guys,
Can someone suggest me an Omni and a directional antenna for up to 6 GHz frequency. I want something with decent performance which however won't break the bank. I have noticed the Aaronia ones (OmniLOG 70600 680MHz - 6GHz) and the HyperLOG 7060 (700MHz-6GHz) if anyone has experience with them.
Thanks!
Aris
Do you really want omnidirectional, as in spherical pattern, or as in cylindrical? For a wide band antenna in a cylindrical pattern you want to consider a discone antenna. At the spread of frequencies you want to look at they are pretty flat across their functional range.
Thanks for your replies!
I need an omni antenna to capture and measure wireless streams (including 802.11ac hence I need one above 6 MHz) and a directional one for more specific measurements.
So I think a spherical one and not a cylindrical will do.
