Poll
What OS platform would you like to see lxi-tools ported to next?
Windows
macOS
Other
Don't port it - Linux is the future for all!
Author Topic: Open source lxi-tools and liblxi v1.0 released for GNU/Linux  (Read 106993 times)
Offline lundmarTopic starter
Re: Open source lxi-tools and liblxi v1.0 released for GNU/Linux
« Reply #100 on: December 01, 2017, 02:38:07 pm »
Following the usual rapid release cycle I have made a new release of lxi-tools available.
For an overview of the changes please see https://github.com/lxi-tools/lxi-tools/releases/tag/v1.13
This release adds a new simple benchmark feature. Also, some important fixes has gone into the screenshot feature.
Thanks to BloodyCactus for helping out ironing out the remaining issues with the Rohde & Schwarz HMO 1000 screenshot plugin :-+
This release is available for install via the snap stable channel:
$ snap install lxi-tools
« Last Edit: December 01, 2017, 03:05:12 pm by lundmar »
https://lxi-tools.github.io - Open source LXI tools
https://tio.github.io - A simple serial device I/O tool
Offline HoracioDos
  • Country: ar
  • Just an IT monkey with a DSO
« Reply #101 on: December 01, 2017, 07:11:05 pm »
Please stop improving this thing. I'm getting tired of compiling it almost every week  :-DD
« Reply #102 on: December 01, 2017, 07:19:12 pm »
Ha ha HoracioDos :D
I can highly recommend you install via snap instead - it updates automatically. No need to manually compile stuff anymore ;)
Offline HoracioDos
  • Country: ar
« Reply #103 on: December 01, 2017, 07:28:44 pm »
I prefer flatpak or old school compile
« Reply #104 on: December 01, 2017, 07:34:26 pm »
Well, it looks like snap is winning over flatpak in the popularity race... just saying ;)
Either way, they are not that much different. They solve some of the same issues but snap provides a more straightforward and polished interface for end users.
« Last Edit: December 02, 2017, 02:40:01 am by lundmar »
« Reply #105 on: December 01, 2017, 08:29:37 pm »
hmmm
> /snap/bin/lxi --version
cannot change current working directory to the original directory: Permission denied
> sudo /snap/bin/lxi --version
> cd /tmp
> lxi --version
lxi v1.13
oh, solved my own problem, posting here for posterity. You get the above error if you run it when your in an NFS mounted directory/path.
Oh, by the way. I don't know why I didn't think of this before but you can try install the snap with disabled confinement like so:
snap install lxi-tools --classic
Then of course rerun the snap alias command if you want to have it recognize the 'lxi' command.
Try it out - maybe that will solve your permission denied on NFS filesystems.
Offline crispus
« Reply #106 on: December 10, 2017, 04:25:16 pm »
I have a couple of suggestions:
1. a parameter for discover - either the network adress, interface name, etc (when you have many interfaces it takes some time)
2. I'm not able to take a screenshot on DM3058:
user@host: /s/l/out $ bin/lxi discover
Searching for LXI devices - please wait...
Broadcasting on interface lo
Broadcasting on interface eth0
  Found "Rigol Technologies,DM3058,DM3XXXX,01.01.00.02.02.00" on address 192.168.1.144
user@host: /s/l/out $ bin/lxi screenshot -a 192.168.1.144 screenshot
Loaded rigol-dm3000 screenshot plugin
<I can hear a beep on the multimeter>
<some time after>
Error: Read error (timeout)
Error: Failed to receive message
I do have the latest version built from github.
I know I'm numskull, but I look around me and I feel better.
« Reply #107 on: December 10, 2017, 04:38:45 pm »
Perhaps I'll add an option for which interface to broadcast on. Something like:
$ lxi discover --interface wlan0
For now, to speed things up a bit, you can decrease the timeout. Usually '--timeout 1' is sufficient.
<some time after>
Do you have the latest firmware from Rigol installed?
I believe that the screenshot plugin has been tested with a DM3068 by PeDre. Perhaps there is a subtle difference in how it retrieves the screenshot for the two models.
Offline crispus
« Reply #108 on: December 10, 2017, 04:51:09 pm »
I didn't (yet) upgrade the multimeter; it is as I received it (version 01.01.00.02.02.00)
I'll try to upgrade it and post the result.
The timeout workaround is good, now it takes 3 seconds instead of 10.
Offline crispus
« Reply #109 on: December 10, 2017, 05:57:03 pm »
If helps, I updated the firmware to the latest version and same error (timeout).
On MSO1104Z-S, DG4062 and DSA815 screenshot works with no problem.
« Reply #110 on: December 10, 2017, 07:41:19 pm »
Hello Martin (lundmar),
just for your information.
The Rigol DM3068 only works without a waitlock flag. The flag may be set automatically when the VXI connection is established. The waitlock flag is used by many VXI functions as a parameter, e. g. device_read, see parameter Device_Flags.
The DM3058 may not work because of this. I have not received any feedback from anyone about this device and my program.
My VXI-simulator ignores this flag. The Rigol DS6000 and DG4000 with old firmware are also affected.
Peter
Edit:
What I wrote can't be the mistake. The IDN is received by the Rigol DM3058,
so the waitlock flag isn't the problem.
Ahh right, yes - the DM was the one you simulated. Either way, I've disabled any locking requests during establishment of the VXI-11 connection. It might fix the issue.
« Reply #111 on: December 10, 2017, 07:47:29 pm »
Ok. I've updated liblxi so that the lxi_connect() function does not try to set up any locking during establishment of the VXI-11 connection. Please update and try it out.
In case you don't want to bother with manual compilation the snap version should already be available on the edge channel.
Snap build status can be monitored here: https://build.snapcraft.io/user/lxi-tools/lxi-tools.snapcraft
« Reply #112 on: December 10, 2017, 08:15:08 pm »
Doh!
I've just studied the documentation for DM3058 and DM3068.
It seems that the SCPI command that we use to request screenshot data ":display:data?" is actually not supported on these instruments.
It might be an undocumented feature but it does not seem to be the case.
Looks like we will have to remove the rigol-dm3000 plugin.
@PeDre , you agree?
« Last Edit: December 10, 2017, 08:21:47 pm by lundmar »
« Reply #113 on: December 10, 2017, 11:18:36 pm »
lxi screenshot -a 192.168.1.59 -m rigol-2000 #Works fine now
1. Can there be a option for png instead of bmp? png are smaller.
The image format depends on which formats the instrument supports. PNG is certainly the preferred format but not all instruments support it. The Rigol 2000 series supports PNG for internal storage of screenshots but it is not documented whether it is possible to retrieve PNG remotely. Please try out the '"rigol_2000_png" branch and let me know if it creates a proper PNG for you. If not I'm afraid it is not possible unless the lxi tool itself starts doing BMP->PNG conversion but I think that is a bad idea. I would rather provide the raw material straight from the instrument and then the user can do as they please.
Update: The screenshot command now supports redirecting the screenshot image data to stdout. To do so simply use '-' as the output filename. This means it is now possible to pass on the captured image to external tools for image processing, such as converting it to a different image format. For example, to convert to .jpg using imagemagicks convert tool:
This feature will be included in the upcoming release. It is already available in the snap edge channel.
« Last Edit: December 10, 2017, 11:23:40 pm by lundmar »
« Reply #114 on: December 11, 2017, 02:44:39 pm »
@PeDre , you agree?
I have received feedback from two users that the Rigol DM3068 (Firmware 01.01.00.01.08.00.01 and 01.01.00.01.09.00) with the SCPI command ":DISP:DATA?" and my program works. This applies to the LAN and USB connection.
Peter
Ok good - so it is just an undocumented feature.
I found Wireshark protocols in my records.
The error was the timeout when creating the connection (CREATE_LINK). The timeout could then be used for write or read commands.
Peter
Ok, then my latest changes should hopefully solve the issue.
Thanks for the helpful input Peter :-+
@crispus, Please test latest git or snap and let us know if works or fails. Also, thank you for testing  :-+
Man, I wish I had more instruments so I could create a small lab with various instruments for regression and feature testing.
« Last Edit: December 11, 2017, 02:49:44 pm by lundmar »
Offline crispus
« Reply #115 on: December 11, 2017, 03:04:33 pm »
If you refer to https://github.com/lxi-tools/liblxi/commit/12017460e30654e6b10ac99e982bb0d534b9df5e , I tested yesterday and it doesn't seem to work.
I will check again this evening and post the results.
I mentioned that I have also MSO1104Z-S, DG4062 and DSA815-TG. And periodically I could run some regression tests.
« Reply #116 on: December 11, 2017, 03:25:17 pm »
I appreciate the double check. Even I sometimes forget to install the library after updating it he he. Otherwise, the snap is readily available (revision #214 or newer).
If you can confirm/test that your DG4062 and MSO1104Z-S works with discover+scpi+screenshot then I would like to add them to the list of tested instruments. The DSA-815 is already in the list. Thanks.
Regarding regression testing, I might reach out to you if I feel that some testing is needed before a release that includes significant changes.
Offline crispus
« Reply #117 on: December 11, 2017, 08:47:13 pm »
Still doesn't work (neither with snap --edge, nor from source files)
Same error (the following output is from snap):
$ lxi
Usage: /snap/lxi-tools/220/bin/lxi [--version] [--help] <command> [<args>]
$ lxi screenshot -a 192.168.1.144 -
Discover && screnshots works from other instruments:
 $ lxi discover --timeout 1
  Found "Rigol Technologies,DG4062,DG4xxx,00.01.12" on address 192.168.1.67
  Found "RIGOL TECHNOLOGIES,MSO1104Z,DS1xxxx,00.04.04.SP3" on address 192.168.1.149
  Found "Rigol Technologies,DM3058,DM3xxx,01.01.00.02.02.00" on address 192.168.1.144
-rw-rw-r-- 1 user user 141799 dec 11 22:34 fg.png
-rw-rw-r-- 1 user user  20750 dec 11 22:34 osc.png
Maybe it is useful to include in version name the git commits id (tools & lib) in order to be sure on what commit is the binary.
SCPI commands seems to work as well.
« Reply #118 on: December 11, 2017, 09:13:00 pm »
$ lxi
Update 2: Your trace confirmed we get a timeout waiting for response to the screenshot capture command. Please try the following (requires latest because of a fix to interactive mode):
$ lxi scpi --address <ip> --interactive
And in interactive mode please enter the following:
:disp:data?
:system:error?
I'm not fully convinced that your DM firmware supports the first command so I expect you will see a system error message like e.g. '-113,"Undefined header; keyword cannot be found"'.
Thanks - I've added them to the list of tested instruments. Also, I've added you to the list of contributors.
Yeah, I might add that.
« Last Edit: December 11, 2017, 10:49:37 pm by lundmar »
Offline crispus
« Reply #119 on: December 12, 2017, 06:49:29 am »
Yeah, you're right:
$ lxi scpi -a 192.168.1.144 --interactive
Connected to 192.168.1.144
Entering interactive mode (ctrl-d to quit)
lxi> :disp:data?
lxi> :system:error?
lxi> :system:error?
0,"No error"
lxi> :disp:data?
lxi> :system:error?
lxi> ^C
I can't see any screenshot related in the programming manual for DM3058
« Reply #120 on: December 12, 2017, 07:23:23 am »
Yeah, you're right:
lxi> :disp:data?
lxi> :system:error?
lxi> :system:error?
0,"No error"
lxi> :disp:data?
lxi> :system:error?
lxi> ^C
Ok.
Btw., did you upgrade to latest firmware?
It's a pretty weird regression if earlier firmware versions support this command but the latest does not. Or perhaps it is only the DM3068 that unofficially supports it.
« Last Edit: December 12, 2017, 07:41:41 am by lundmar »
Offline crispus
« Reply #121 on: December 12, 2017, 03:03:27 pm »
Yes, it seems that already had the latest version. The tricky part though, in the release notes the version contains an additional 02: 1.01.00.02.02.00 on the multimeter versus 1.01.00.02.02.00.02 in the release notes.
« Reply #122 on: December 12, 2017, 04:04:42 pm »
He he, yeah - those two numbers can make you go blind trying to spot the difference.
So, since the screenshot plugin certainly won't work with the DM3058 I'm thinking I will add to the description that it only works with DM3068.
Or at least, I will assume it to be working with DM3068 until someone tells me otherwise.
Either way, thank you for your testing. I'm sorry we couldn't make it work.
As a last resort, you could try ask Rigol to add screenshot support to their firmware but it might be a futile task - I don't know how much Rigol listens to their users.
« Last Edit: December 12, 2017, 04:24:33 pm by lundmar »
« Reply #123 on: December 12, 2017, 09:57:07 pm »
New releases of lxi-tools and liblxi are now available via snap, tarball, or git.
This is a feature and bug fix release.
For a complete overview of changes please see:
https://github.com/lxi-tools/lxi-tools/releases/tag/v1.14
https://github.com/lxi-tools/liblxi/releases/tag/v1.8
A lot of new screenshot plugins have been added which add support for many of Siglents instruments.
Also, the screenshot command has been improved so it is now possible to redirect the captured screenshot image directly to external tools for simple or advanced image processing such as resizing, scaling, adding text, format conversion, etc. It's quite a powerful feature. For example, to embed a time stamp in the image, upscale the image to 150%, and convert it to JPG, simply use the lxi tool in combination with e.g. ImageMagicks image manipulation tools like so:
$ lxi screenshot -a 10.0.0.42 - | convert -fill white -draw "font-size 16 text 100,100 '`date`'" -scale 150% - screenshot.jpg
Or, to add a label with time stamp:
$ lxi screenshot -a 10.0.0.42 - | montage -geometry +0+0 -background white -label "`date`" -scale 150% - screenshot.png
ImageMagicks image manipulation tools support various image operations and over 200 image formats which should satisfy the needs of most users :)
Also, I would like to put a big thank you to Siglent who has been very helpful to test and make sure that lxi-tools works well with all of their LXI compatible instruments  :-+
« Last Edit: December 13, 2017, 02:36:27 am by lundmar »
The following users thanked this post: Octane
Offline dpenev
« Reply #124 on: December 13, 2017, 05:57:41 pm »
Hi lundmar,
I have tested the latest lxi tool v1.15 and screenshot is working fine on my Siglent SSA3021X
A minor note which would be a bit more convenient for me is if I would able to write directly to my share
At the moment I get an error
lxi screenshot -a 192.168.1.61 /share/scr2.bmp
Loaded siglent-ssa3000x screenshot plugin
Error: Could not write screenshot file (No such file or directory)
Thank you for your work.
Dimitar
