Author Topic: Opening a Testboy TB-3000  (Read 5312 times)
Offline OchsenfroschTopic starter
« on: May 25, 2017, 07:35:22 am »
Hi, I opened my Testboy TB-3000 multimeter. It's about 70,-€ in Germany.
Have some impressions.
Offline Fungus
Re: Opening a Testboy TB-3000
« Reply #1 on: May 25, 2017, 07:44:41 am »
It might just be the angles, but...these look awfully close to each other on the input protection. I think a spark might be able to jump that distance.
And the soldering...  :wtf:
« Last Edit: May 25, 2017, 07:50:16 am by Fungus »
Offline Fungus
« Reply #2 on: May 25, 2017, 07:47:43 am »
Looks like someone cleaned their soldering iron at the current shunt...
That's called "calibration".
Looks like the resistance was a little bit high so they added some extra solder to fix it.  :popcorn:
TÜV Süd/GS approved
The design looks OK but I bet the meter they submitted for approval wasn't soldered/assembled by the same person that soldered/assembled yours.
« Last Edit: May 25, 2017, 08:07:12 am by Fungus »
Offline Towger
  • Country: ie
« Reply #3 on: May 25, 2017, 08:07:30 am »
To quote  Dave, it is done by nude virgins or old gray beards with their tongue the correct angle.  But, I think you are correct, in this case old Bathild looked at the meter in a test rig and cleaned the tip of her soldering iron on the shunt.
Offline Fungus
« Reply #4 on: May 25, 2017, 08:46:16 am »
No, it's true!
Normally they're manufactured a bit low and they put a few "nips" in them with a pair of side cutters until it reaches a known value, like this:
(sort of like laser trimming but without the lasers)
If it's a bit too high? Add a blob of solder!
« Last Edit: May 25, 2017, 08:55:33 am by Fungus »
Offline Fungus
« Reply #5 on: May 25, 2017, 10:20:18 am »
Or... they might just have been cleaning their soldering iron.
Offline WackyGerman
« Reply #6 on: May 25, 2017, 11:38:39 am »
Horrible build quality  :scared:. I am in doubt that the TÜV / CE certification is real . Scammer  :--
Online Huluvu
    • ECM Home
« Reply #7 on: May 25, 2017, 02:48:43 pm »
Same issue with my TB 3000 which I posted in 2013  :--
https://www.eevblog.com/forum/testgear/soar-multimeter/msg192944/#msg192944
"Yeah, but no, but yeah, but no..."
Offline Hydrawerk
« Reply #8 on: May 25, 2017, 04:59:54 pm »
Is this a rebranded Mastech or something??
Offline stj
« Reply #9 on: May 25, 2017, 05:26:39 pm »
the certification is only done on a submitted device - the one they built carefully and de-fluxed first!!
Offline PointyOintment
  • ↑ I scanned my face
« Reply #10 on: May 27, 2017, 05:27:54 am »
Yeah, before I put it back together, I bent them apart and put some hotglue (forgive me) between the leads.
Careful with that. When you put glue on it, I think you have to worry about creepage distance, which is greater than the clearance requirement for a given voltage. With hot glue, though, you probably couldn't easily put on a blob that's too small.
I refuse to use AD's LTspice or any other "free" software whose license agreement prohibits benchmarking it (which implies it's really bad) or publicly disclosing the existence of the agreement. Fortunately, I haven't agreed to that one, and those terms are public already.
