I got the meter today, and here's my initial impression. It's a bit bigger bigger than I thought, blacker and more orange-y as well, and it feels quite light. Viewing angles on the display are excellent, and it remains readable at all angles. The backlight is nice and even with no noticeable hotspots, but it times out after just one minute with no way to force it to remain on. The display is responsive with the bargraph being particularly snappy, and this also shows the current range (e.g. 0-6, 0-600, etc). The dual display function is limited to displaying the frequency of the measured AC voltage/current, which is a little disappointing. On start up, the meter is autoranging and will select AC/DC measuring automatically based on the input signal - while this can be overridden by pressing the A/V buttons to force AC or DC mode, there is no way to manually set the range. Similarly, when pressing the Ohm/continuity/diode/capacitance/etc button, the meter will try to guess what you're trying to measure, which works as poorly as one might suspect, though it's easy to loop through the modes by repeatedly pressing the button. A reassuring "click" from one or more mechanical relays can be heard as you switch between the modes, and it will beep angrily at you (and refuse to switch) if you try to choose current measurement while the probes are in the wrong holes (and vice versa). The selected mode is easy to see thanks to the corresponding button lighting up. The min/max/avg functionality is good, with the meter emitting a gentle beep when the value changes. The kickstand and probe holders on the back are well designed and work very well, and the supplied probes are of high quality with supple silicone leads. The kit also includes a K-type thermocouple adapter with its own internal coin cell battery. This is a meter that has clearly been designed for field use, by a service engineer, and as such it is probably less suitable in an electronics lab.
I like:
- The display and backlight
- Buttons for selecting mode
- That it's IP 64 rated
- The A/V safety features
- The kickstand and probe holders
I don't like
- The inability to manually set range
- The backlight timing out after 1 min
- The toy-like colours
- It's a bit bigger than I hoped!
Edit: Note that the photos have all been taken with the protective plastic still covering the screen - I haven't decided yet if this is a keeper or not!
