Author Topic: Test Leads for UT61E  (Read 1131 times)
Offline ko4nrbsTopic starter
« on: April 21, 2023, 10:27:45 pm »
Can someone recommend a good set of test leads for a UT61E multimeter?
Bill
Offline mwb1100
Re: Test Leads for UT61E
« Reply #1 on: April 21, 2023, 10:37:04 pm »
https://probemaster.com/ - I put off buying some of these for so long because the photos made me think they'd be uncomfortable to use.  I was totally wrong - they are every bit as good as people say.  And you can get them however long you like and can opt for straight banana plugs instead of the right-angled ones that are usually used (and that I find more irritating than not).
If you're a Fluke fan, then TL-71 leads are nice - much nicer than the TL-75s that usually come with their meters.
If you're in the EU or already buying something else from welectron.com (to cover the shipping), then these Brymen leads are great and cheap (10 EUR + shipping):
  - Brymen BL21S2-T4SC Silicone Test Leads
« Last Edit: April 21, 2023, 10:43:39 pm by mwb1100 »
Offline Martin72
  • Testfield Technician
« Reply #2 on: April 21, 2023, 10:43:06 pm »
I´ve bought testleads from probemaster for my brymen by welectron and never regret it.
Like them more than the ones we have at work from fluke.
« Reply #3 on: April 22, 2023, 12:56:08 am »
What size do I need for the UT61E?
Bill
Offline Per Hansson
« Reply #4 on: April 22, 2023, 08:05:43 am »
Bill
Any 4mm standard test lead will fit.
I have bought these and they work great with both the UT61E and my Flukes:
Probe Master 8017S Softie Test Leads 120cm
Offline skander36
« Reply #5 on: April 22, 2023, 09:52:54 am »
Any 4 $ test lead is good enoug for this meter.
Offline Martin72
« Reply #6 on: April 22, 2023, 02:44:47 pm »
Boooo.... ;)
