Author Topic: Korad 6005D Power Supplies in Series  (Read 1449 times)
Offline connectTekTopic starter
« on: October 03, 2020, 02:26:47 am »
Just wondering if it's safe to connect 2  x Korad 6005D power supplies in series, safely?
Cheers.
Offline radiolistener
  • Country: ua
Re: Korad 6005D Power Supplies in Series
« Reply #1 on: October 03, 2020, 03:15:38 am »
Cheers.
If you connect they in series, you will get 60+60=120 V.  :-DMM
This is definitely is NOT SAFE! Such voltage is very DANGEROUS!
Even 60 V is not safe.
I suggest you to treat any voltage above 30 V as dangerous.
And at some conditions even 20 V may be dangerous.
« Last Edit: October 03, 2020, 03:21:01 am by radiolistener »
« Reply #2 on: October 03, 2020, 08:48:11 pm »
Just want to play with +15_0_-15vdc .
Is it ok with the korads?
Offline ceoxrad
« Reply #3 on: October 03, 2020, 09:02:48 pm »
Yes, it will be fine, I use two different power supplies in series to get split rail power everyday
Sorry for any mistake in my English
« Reply #4 on: October 03, 2020, 10:38:28 pm »
Thankyou
Offline tautech
« Reply #5 on: October 04, 2020, 01:31:09 am »
Cheers.
Yes well some users still require a HV DC current source dangerous or not.
To series 2 supplies of the same make is not uncommon and clues to max voltages for doing so are in the datasheets listed as their max elevated voltage WRT mains ground.
This same question came up recently about multi channel PSU's in series mode being placed in series for even higher voltages.
Here, 120 VDC @ 6A is possible:
Avid Rabid Hobbyist.   Come visit us at EMEX Stand #1001 https://www.emex.co.nz/
