Author Topic: Siglent SDG2042x output channel led failure  (Read 448 times)
Offline natman69Topic starter
« on: December 04, 2022, 11:32:26 am »
I've found that on my SDG2042x the output led is died on channel 1  |O
I want to replace it but before opening the case I want to know which new led I need to buy (smd size, Vf, etc.). So I can order in advance the needed correct spare part.
Also I have not found any picture of the front panel pcb.
Someone can help?
Thx
Offline tautech
Re: Siglent SDG2042x output channel led failure
« Reply #1 on: December 04, 2022, 06:55:24 pm »
I'll try and get this from Siglent for you, might take a day or 2.
I had a 1000 series apart years ago but never took any notice although I'd imagine they are nothing special and in 0603 or 0805 form factor.
Avid Rabid Hobbyist
« Reply #2 on: December 04, 2022, 07:01:33 pm »
Thank you  :-+
Offline tautech
« Reply #3 on: December 05, 2022, 04:32:28 pm »
0603 LED info from Siglent.
Avid Rabid Hobbyist
« Reply #4 on: December 05, 2022, 07:39:35 pm »
Thank you very much!  :-+
I will keep you informed about the reparation. And I will post pictures of the keypad pcb.
