Hi, I am an inexperienced hobbyist in need of help selecting an oscilloscope for Arduino/Raspberry Pi robotics projects.
Will really appreciate benefit of experienced/expert opinions.
Many thanks.
I can only speak for this hobbyist - I just want the most economical solution and don't want to make the mistake of buying an inadequate instrument that I subsequently need to replace because of inadequate research.
I am a fellow hobbyist, so my opinion is definitely NOT an expert's opinion. But having the "engine starting" not so long ago, I remember how it was like. The discussions about which scope is useful/good are no doubt very valuable. But I suggest perhaps you should see what problems stand in your way first.
If I am to say: to really do electronics right, you should learn calculus first - you (or I should say, most) would not get started in electronics. No doubt calculus is both important and enlightening in solving many electronic problems. But you don't need that just to play with Arduinos/Raspberry.
At the get-go, I saw all those candies and I want them. I ran in circles at the starting-gate. I eventually just got moving with a low cost DMM, then later added a low cost Scope. At the get-go, I wanted to have a 100,000 count DMM, but it turns out I don't need it. I wanted to have a 100mhz 1meg datapoint scope. Turns out in my case I rarely use a scope... I still want a 100,000 count+ DMM, but I don't need it to get started. I still like a 400Mhz scope, but I don't need it to get started..
Don't worry too much about having to replace your equipment. By the time you learn enough to need a better DMM or a better Scope, there will be far better choices (performance) products then. You also would be much better equipped to find one much more suitable for your need. Besides, there is a good chance you may make newbie mistakes that even the very best equipment may not survive. So top shelf stuff may not be best for a new-newbie.
The trouble with a Lamborghini is, you really don't want to learn how to drive with it.When you get to the point of doing the upgrade, the old/cheap stuff that you used to learn with will always have a home. A second scope or a second DMM (low cost starter) will always have a use.
Again, just a fellow novice merely a steps or two ahead of you - trying to share what I know.
Rick
