Author Topic: Oscilloscope for ham radio & electronics, DS1202Z-E and SDS1202X-E questions  (Read 7208 times)
Offline BebopTopic starter
I'm looking to get an oscilloscope for ham radio work (it'll be HF and below) and general electronics work.
I've had a look at what's about and price-wise the Rigol DS1202Z-E seems the most tempting, but the Siglent SDS1202X-E is a similar price and spec, I also considered Rigol DS1054Z but I'm wondering if the extra headroom of the 200MHz might be better with ham radio work.
A couple of specific questions having had a look at the spreadsheet.
As I see it the Rigol has a waveform update rate of only up to 30,000 wfms/s compared to the Siglent with 100,000 wfms/s, however the Rigol has a memory depth of 24M compared to only 14M for the Siglent.
Additionally the Rigol has Intensity Grading Display of only 64 to Siglents 256 and shared controls compared to Siglents independent controls.
I'm just looking for advice as to which of the features are 'more important', is it worth the drop in memory depth for the gain in wfms and IGD?
Thanks,
James
Online Fungus
You're asking all the right questions, except one.
200Mhz - definitely go for that.
I wouldn't worry about wfms/sec or IGD.
The real decider for radio work should be the FFT/frequency analysis. The Siglent definitely wins on that.
« Last Edit: December 02, 2020, 11:28:50 am by Fungus »
The following users thanked this post: Bebop
I wouldn't worry about wfms or IGT.
And it's 500uV/div sensitivity and 1 Mpts FFT.
Online tggzzz
You haven't said what you want to measure and why.
Frequently a scope is the wrong tool for RF, a spectrum analyser being more appropriate.
When considering a scope, be very aware of the consequences of sensitivity, linearity, and for a digitising scope, the number of bits.
Thanks for the replies. So is the memory depth not too big of a deal?
In terms of what I'd be measuring, yes I know that a spectrum analyser in many situations is more helpful but that is well outside by price range and also not so helpful for general electronics debugging, for instance I'm currently working on an oscillator which isn't working, but a scope would be helpful in seeing what's going on. I'm guessing that the FFT spectrum analyser feature of the scope could be very useful.
So the frequency analysis is better in the Siglent? That does seem like an important point. I missed that question as the details weren't on the spreadsheet!
The SDS1202X-E FFT is about as good as it gets for this class of DSO yet until you also study the user manual that will be updated with later FFT functionality that was added in firmware you can't see the full picture of what these can do from just the datasheet.
Unless you're into very long records/captures using both channels when it is shared the lesser mem depth shouldn't be a problem.
Online Fungus
It depends on what you're using the scope for.
If 'radio' is a principle use then I'd say the memory's less important then some other things.
Offline kg4arn
I am a Ham and I build/study HF electronics. I have an Agilent DSO3024A with 4MB of memory. I also have a dedicated Spectrum analyzer.
My advice is go for bandwidth first as long as quality and usability are on par. I have not be limited by my meager 4MB.
I have found the Scope fft not very useful due to the dynamic range limitations but that is inherent and shared limitation for all scopes unless they have a specific SA front end.
4 channels is incredibly useful if you can afford it.
Online tggzzz
I suggest you understand the limitations on your measurements due to limited linearity and limited dynamic range and an oscillator sufficient for looking at waveform shape in the time-domain.
For general purpose debugging, any scope is useful. For looking at the phase noise in an oscillator or multiple low-level signals or lock-in transients, less so.
As for cost, I have two general purpose spectrum analysers capable of >18GHz (HP8562A, Tek492). The more expensive one cost me £350. Of course I needed patience before I located those!
For looking frequencies and how they change over time, it is hard to beat a modulation domain analyser. Mine cost me £400, but again I needed patience.
With any datasheet, the trick is to read and understand what isn't stated.
Offline mawyatt
If you just want to "investigate" RF things below 1GHz the TinySA is a remarkably capable tiny spectrum analyzer, and cost well under $100. Couple this with a nice DSO like folks are mentioning and you've got sub-1GHz RF things well covered :)
Best,
~Wyatt Labs by Mike~
The following users thanked this post: Fungus, Bebop
Online Fungus
Yep. I forgot about that one.
For the price of a Siglent you could get a Rigol+TinySA. Definitely worth checking out.
There's plenty of videos of TinySA out there...
Offline mawyatt
I can't say for the DSOs mentioned here but on the SDS2102X Plus I have the FFT is quite good. If you didn't know where the FFT display came from (a DSO) you would think it was from a dedicated FFT analyzer, it's that good :)
Maybe some of the FFT DNA from the SDS2000X+ has trickled down to the SDS2102X-E SDS1202X-E ::)
Best,
« Last Edit: December 02, 2020, 06:19:06 pm by mawyatt »
Online Wallace Gasiewicz
My favorite piece of equipment for Ham radio equipment and fixing things is an HP 8935 service monitor.
No real scope in this thing though, the scope it has is audio and pretty useless.
Combines SA and RF gen and AF gen, power meter and Modulation in one big lump
It is also a good HF, VHS, UHF receiver.
Online Fungus
But it's not going to go up to 1GHz or have the sensitivity of a spectrum analyzer.
HP 8935:
Goes to ONE GHz just fine (rated for this) It is really a cell phone tower analyzer so has to be good at cell freq.
Then again from 1.7 GHz to 2 GHz (cell Freq)
No too accurate below 10 MHZ but really OK down to maybe 1 MHz
Not as accurate as power meter, but pretty good
Twin audio generators
When you are testing a radio you can modulate the Mhz input antenna signal with one audio generator and use the other audio generator to inject audio into mic input.
Modulates signal either AM or FM wih big ranges on both modulations
Has about 100 Watt input limitation.
Smallest range is 10 KHz on SA, plenty for any repair job. So you can easily see one KHz side band. Freq counter is down to one Hz, limited by the standard. If I need better I drag out the old two ton Marconi
« Last Edit: December 02, 2020, 05:52:05 pm by Wallace Gasiewicz »
Offline mawyatt
Never said it goes to 1GHz, that's why I mentioned the TinySA. It's pretty good up to ~100MHz, and quite good below 10MHz.
It performs like a dedicated FFT analyzer at the lower frequencies (of course one needs to set it up properly, which isn't obvious unless you fully understand FFT basics). You would never expect that a DSO 8 bit ADC is behind this. Couple that with the superb low noise, high resolution, wide-band front end and Siglent just got this SDS2000X+ series DSO right  ;)
Like mentioned, hopefully some of the 2000X+ DNA has trickled down to the other DSOs.
Offline james_s
I don't think so. My main scope has 8M, that was the optional high end "deep memory" at the time it was made, and that's way, way more than I've ever needed. If you capture a really big chunk of waveform all it means is you've got pages and pages and pages of waveform to scroll through and everything just takes longer to process. You're better off learning how to use triggering properly and capture the stuff you want to look at. instead of trying to grab everything and sort it out after the fact.
In reverse, X Plus DNA came from SDS1202X-E the first DSO from Siglent to use the Zynix range of processors.
Their UI evolved from SDS2000 then SDS1000X then SDS2000X, later X-E models and X Plus was following on from SDS5000X with the new UI these 2 model series use today both of which are touch and mouse capable.
Online 2N3055
  • Country: hr
I'm afraid that is horribly simplistic way of looking a things.
Some things are simply long processes that you need to sample for long time with maximum bandwidth.
For that, you need long memory.  If you're looking at repetitive signals at short timebases, even 10k samples are enough.
To get 500ms of startup transient with 20 MHz bandwidth and 100MSPS/s you need 50MS memory. For higher bandwidths, much more..
There is no replacement for input bandwidth, there is no replacement for long sample memory, if you need any of those.
I think it would be more correct to say that you never did things that needed more memory.
I also don't run out of memory most of the time with KS MSOX3000T, and that one has even les memory than your scope. But occasionally, I have to fire up Picoscope. I do agree that sifting through 100MSPS of data is much easier on 24" monitor on PC though....
Dr. Richard W. Hamming
Online Fungus
That's quite a specialist job though, and one that could be handled by a cheap(ish) USB 'scope if the need arises. No need to spend insane amounts of money on an oscilloscope just-in-case.
The following users thanked this post: james_s
Online nctnico
It depends on what you are working on. Deep memory is very handy to make longer captures and then zoom in on details or move left/right to see more of a signal (but the Siglent scope can't do the latter because it only captures enough data to fill the screen even with the memory length set to a higher number). More memory gives more possibilities and less chance of needing to 'make do'. BTW another option is the GW Instek GDS-1202B. This model has 10Mpts per channel and uses all the memory you tell it to use. Otherwise it is pretty much on par (both in price and the hardware) with the Siglent you selected.
The following users thanked this post: werediver
Offline mawyatt
Well then, that should be a superb FFT implementation regarding the SDS1202X-E  ;)
Best,
SDS2000X Plus is better, much better and so it should be at 4x the price.  ;)
While neither are a SA the principles of usage are similar however unlike a SA the timebase setting in a scope can influence FFT results. Some scopes with tiny FFT only require a small # of waveform cycles to be displayed while with larger Mpt FFT the more info FFT has to work with (more cycles) the better the result.
Garbage in = garbage out.  ;)
Online nctnico
Not always. In many cases you don't really know at what timeframe an event takes place but usually the areas of interest are easy to spot (think about the power up sequence example from 2N3055). The advantage of deep memory is that you can capture a lot at a high enough samplerate to capture every tiny detail without needing to re-capture an event ad nauseam. There is also a causal relation between every event in a signal. If you have to capture a signal in little bits and pieces you can never be sure that signal piece C occurs due to / whether piece A or piece B being present in a signal. In the end the trigger abilities of an oscilloscope aren't that sophisticated.
Offline james_s
There are niche cases where super deep memory can be a benefit, if you anticipate encountering those cases often then it may be worthwhile to put more weight on that feature, but personally I put very little on it. The scope I use most often is a TDS3000 which has by modern standards very shallow memory, 2.5kpps IIRC. Occasionally I find that limiting but most of the time it isn't enough of an issue for me to go drag the boatanchor off the bench if I'm working on something in another room. I came from an analog scope that had no memory at all though.
