Hi guys,
I need help in getting a new oscilloscope. I own 2 oscilloscope, 100mhz LEADER LS8106 CRT oscilloscope, and Hantek DSO5102P. I used mostly the Leader on my bench, and Hantek is for traveling to customer place. My Leader is getting a bit too old with a little bit of problem here and there. I have the service manual courtesy of leader. I tore it apart couple of years back to replace some cap and a little bit of calibration. Recently it become laggy, as in when I turn the knob or press some, it will take a few sec to respond, if it's warmed up it might become responsive again. Since I used this to generate money, and generally I just want some new shiny things on my desk I decide to try to upgrade it to newer DSO.
My use case is very simple, I use it mostly to look at a very low level sinewave signal circa 2-4mVpp, at frequency of 2-12MHz. I used the DSO mainly to look at x-y trace of linear encoder and some other normal analog signal. Now, when I tried to use the Hantek DSO to replace my Leader as my main bench oscilloscope, I can't get it to show me a stable signal (4mvpp 4MHz). I'm not well versed in DSO, but my guess is that I can't get a stable trigger, which is funny since it should have much more triggering capability compared to my cro, and no matter what kind of available triggering that I tried it will still not be able to show a stable signal. My CRO just need a twist of the trigger level and a bit of hold here and there and it will be able to show the signal. Attached a pic to show how the DSO display my signal and how my CRO display my signal. Both are connected to the same point at the same time, also imagine the DSO signal jumping around all over the screen...
One nice sales person came to my place and showed me the TEK MDO32. It still unable to show me a my 4mvpp sine signal, except when i hit the fast acquisition mode, and that is also only through the coloured intensity grading ( with big fat shadow on either side of the signal). I'm not sure I can or want to afford the MDO32. My budget is ard usd1000.
So the main question is, what kind of trigger or function do I need in the DSO to be able to sort of mimic how my CRO behave ? What model DSO do you guys recommend ? Things I tried with the Hantek that does not work : changing the persistence setting, trying different type of triggering and their parameter, averaging (kills my ability to tune the signal), BW limit to 20MHz, AC coupled trigger, HF Reject, noise reject, etc. Only if my signal goes above 20mvpp I can get the DSO to trigger properly, but still waveform is less well defined compared to my CRO.
Thanks for all your input.
