Author Topic: Oscilloscope Music on DSOs- Post your Results  (Read 8855 times)
Offline Martin72Topic starter
  • Testfield Technician
Re: Oscilloscope Music on DSOs- Post your Results
« Reply #25 on: April 14, 2024, 07:00:09 pm »
Hmm....Good question, will test it.
The following users thanked this post: egonotto, Anthocyanina
« Reply #26 on: April 14, 2024, 07:19:45 pm »
ERES is possible in XY mode, the difference is clearly visible.
Will upload a short clip (in progress).
« Reply #27 on: April 14, 2024, 07:23:25 pm »
(first 30sec: Normal, next 30sec: Eres 3.0, same scenario)
The following users thanked this post: egonotto, tautech, Mortymore, Grandchuck, Anthocyanina
Offline artag
« Reply #28 on: April 14, 2024, 09:03:17 pm »
Do the siglents have good Z modulation too ?
My Agilent has only blanking, not variable intensity.
It's important for scopetrex/vectrex use
« Last Edit: April 14, 2024, 09:11:15 pm by artag »
« Reply #29 on: April 14, 2024, 09:21:20 pm »
Member TopQuark mentions he uses a colored grading setting that will assist in showing intensity.
Siglent XY is normally just a blue trace but if you study some of his examples you can see subtle trace color changes.
Online bdunham7
« Reply #30 on: April 14, 2024, 09:37:17 pm »
AFAIK there's no Z-axis functionality at all, blanking or variable.
« Reply #31 on: April 14, 2024, 09:44:13 pm »
Yep.
The first time I saw anything about a Z-axis was in the XY menu of the Rigol DHO800.... :-X
Online ebastler
« Reply #32 on: April 15, 2024, 05:35:49 am »
Yep.
Ah, that must have been where I saw it too. (In the DHO1074, to be precise.)
I got my Asteroids arcade board out yesterday and connected it to the SDS800X HD, to see whether I finally have a DSO which does a credible job displaying that vector game. Only to find that the scope does not support a Z input (for beam intensity modulation) at all. Bummer...
I'm afraid the excitement about CROs finally having become totally redundant is premature.  :-\
Online Fungus
« Reply #33 on: April 15, 2024, 07:02:07 am »
Rigol DHO800:
Online Fungus
« Reply #34 on: April 15, 2024, 07:07:11 am »
Should have got the Rigol...
Online ebastler
« Reply #35 on: April 15, 2024, 07:34:10 am »
I had purchased the Rigol (DHO1074), and while it supported Z control, its XY performance was less than convincing. More importantly, there were other things I disliked, as discussed in the DHO1000 thread in January -- enough of them to make me return the scope, sacrificing the great Black Friday price I got.
Online KungFuJosh
  • TEAS is real.
« Reply #36 on: April 15, 2024, 02:12:38 pm »
Rigol DHO800:
That's unstable and choppy. You should see if you can get better performance with lower memory depth, or see if turning off the waveform box improves it at all.
Offline joeqsmith
« Reply #37 on: April 15, 2024, 02:45:22 pm »
Better than the show us your square wave thread.  IMO, this music thread is a lot more informative.
Rigol DHO800:
That Rigol looks like what my old scopes would show.
Online Fungus
« Reply #38 on: April 16, 2024, 01:31:30 pm »
I might give it another go.
That video was recorded over the web interface which might not help either.
Online KungFuJosh
  • TEAS is real.
« Reply #39 on: April 16, 2024, 01:53:06 pm »
I assume it's similar for your Rigol, but the web interface on my Siglent has a limited frame rate. I'm guessing 15fps. If you want smoother videos, it should be at least 60fps, which is why I do the annoying recording in front with a cellphone at 4k 120fps.
Offline schmitt trigger
  • Country: mx
« Reply #40 on: April 16, 2024, 02:09:36 pm »
@ Anthocyanina
Did you compose the tune yourself? It is catchy.
What synthesizer did you play it with?
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #41 on: April 16, 2024, 02:42:24 pm »
Aside from the "fun" aspect (video games, turning your scope into a "TV", etc.), Z mode is still being used by quite a few people.  I'm not sure I'm allowed to say who is still using it for what, but I would be interested in hearing from people who (would) use Z mode for "serious" applications.
"Blanking" can also be done using an external trigger-in signal (if available).  This is one way of creating constellation diagrams without a "true" XYZ input (and what I used in this short video, since the RTM does not have a Z input either)
https://www.instagram.com/reel/Csb7hKjJe7Z/
« Last Edit: April 16, 2024, 02:46:39 pm by pdenisowski »
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: egonotto, joeqsmith
Offline Anthocyanina
  • The Sara
« Reply #42 on: April 16, 2024, 04:14:53 pm »
@ Anthocyanina
hi, no, oscillofun is by Atom Delta, and potential is forever is by Chris Allen. I just click play on the music player and record the oscilloscope screen :p
Offline stj
« Reply #43 on: April 16, 2024, 07:42:57 pm »
i need an analog Z input for testing old arcade pcb's properly,
my old D83 RACKMOUNT is huge and heavy - i'd like to replace it with a modern scope, but i must have variable blanking - trigger tricks of on/off blanking isnt going to do it
« Reply #44 on: April 16, 2024, 08:47:33 pm »
Telequipment ?
Nice CRO using a Tek 7603 CRT providing a very crisp trace.
Was my first scope.
Online Fungus
« Reply #45 on: April 17, 2024, 01:39:44 pm »
I recorded my demo by playing the youtube video into my 'scope.
I don't know if youtube audio compression would have any effect.
If anybody has an mp3...
Online KungFuJosh
  • TEAS is real.
« Reply #46 on: April 17, 2024, 01:51:17 pm »
Yeah, you need better quality. You can download wav files here: https://drive.google.com/drive/folders/1UHvGC6-TDywFri7am8YJl5G6svK33qhC
The following users thanked this post: Fungus, pdenisowski
Offline joeqsmith
« Reply #47 on: April 18, 2024, 12:38:15 am »
PC sound card to scope good enough?  Wouldn't think with audio, we need much?   Seems I tried it before with miserable results.   PC scope software out performed it by a mile.
Online KungFuJosh
  • TEAS is real.
« Reply #48 on: April 18, 2024, 01:02:40 am »
Probably fine, assuming it has good volume level and sample rate. Not sure how much the latter matters, but some files are specified.
  • The Sara
« Reply #49 on: April 18, 2024, 05:24:41 am »
i used my pc's built-in audio output for all the recordings, it's not bad as long as you don't use an equalizer or other DSP for your audio out
