Well, sorry, but ASIC situation is not the same in 1000/2000 as in 3000...
Difference is that 3000 has 2 ASIC chips, and those ASIC-s are kind of custom scope customized FPGA-s. They are partially reconfigurable.
1000 and 2000 have only 1 MZ ASIC, and they are configured differently.
This is exactly type of marketing that big companies use, to make you think your low end car is equally awesome as their top end model because they use same spark plugs.
KS scopes have great user experience. They are designed to give you responsiveness, so when you twiddle buttons on them, they make you feel like analog scopes. That is great, and in 3000 series you get great responsiveness, tons of measurements and protocols, and few compromises that might not be a problem for you. Memory is marginally small, but for most uses you get by. If you want to decode long protocol sequences, not a scope for that. But 80-90 % of the time fantastic machine.
1000 and 2000 series have very limited math, protocols and memory compared to 3000 series. So basically even more compromises and none of the good stuff. Only fast UI feeling is left, not much else.
If you want digital replacement for analog scope, they are great. Compared to analog scope they are advanced. And they are fast to operate, like analog scope. If that is your thing they are great. There is none better at that than them.
If you want to buy inexpensive digital scope that is supposed to be digital scope with corresponding workflow, they are completely wrong choice.
We're back to talking features again instead of talking performance. Although the differences between the hardware of the 2000X and 3000X and 3000T series you describe are accurate I'm not sure the practical difference is described accurately. The math listed for the 2000X is "Math waveforms: add, subtract, multiply, FFT, d/dt, integrate, square root, Ax+B, square, absolute value, common logarithm, natural logarithm, exponential, base 10 exponential, low pass filter, high pass filter, magnify" The math listed for the 3000X is "Math waveforms: add, subtract, multiply, FFT, d/dt, integrate, and square root. With the DSOX3ADVMATH option, you get these additional math waveforms: Ax+B, square, absolute value, common logarithm, natural logarithm, exponential, base 10 exponential, low pass filter, high pass filter, magnify, measurement trend, chart logic bus timing, and chart logic bus state." The 3000X offers more features but not by a mile. The difference is measurement trend, chart logic bus timing, and chart logic bus state. The differences in decoding are bit a bit more significant but something like triggering offers almost exactly the same options. A 1000X isn't a 2000X which in turn isn't a 3000T. That should be obvious but all carry the benefits of the ASIC which still offers best in class performance. As I stated in my previous post "Of course you could argue the more limited feature set makes alternatives more interesting but that's another discussion."
3000T also has touch screen (big usability help), zone triggers (great!), math on math, vastly enhanced FFT etc. ADVMATH is not longer an option but comes with the scope, so that is basic math on it.
I tried all three of them, and decided that I have to give more money for 3000T, for what I do.
Again, many people still use scope pretty much like the old analog one and don't use any of the new digital scope enabled workflow helpers. And for those I recommend to try 1000 and 2000 Keysight. They are usually very happy with them.
And, no, I will never concede to anyone that GUI performance is more important than features. It is not. If a slow scope has a measurement you need but you have to wait 10 seconds for calculation, it is still better than the one that doesn't have it, if you need that measurement, that is.
Comparing performance makes sense only if comparing apples and apples.
If you want BASIC scope that is very fast then 1000 and 2000 KS make sense.
If you want capable instrument, Rigol MSO5000 is superior in every aspect to KS 1000 and 2000. Every. The fact is that is still very new and it is not debugged yet. Also, fact that you can buy 350MHZ 4ch Siglent SDS5000X for the price of nicely optioned KS 2000X should make you think. There is no way you can tell me you really think DSOX2024A is better scope than SDS5034X, by any metric...
Not to mention some nice GW Instek , or R&S etc..
That is my opinion, based on my preferences, research, testing of dozens of instruments etc. etc. You have yours.
