Author Topic: Oscilloscopes with more than 4 channels  (Read 2094 times)
Offline JPorticiTopic starter
« on: December 22, 2017, 02:56:37 pm »
In a current project I am using all four channels, but life would be easier if i had more!
Actually in this project i'm not looking at the real waveforms, but at a part of the circuit converts all the higher voltage peaks into microcontroller-readable 5 volt pulses, which is want i want to look at..
At this point i may be good with a logic analyzer (which i have but not here with me) but i thought it would be interesting to know what equipment is available.
And who wouldn't love to have a test drive with a new scope  >:D
i only know of three currently in production:
- Picoscope 4824 has 8 channels at 80 MS/s. should be more than good enough for most of the times i'd rather have more than 4 chan
- Lecroy HDO8000A Series, but bloody expensive.
- Tek MDO5, same
what about the second hand market?
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Oscilloscopes with more than 4 channels
« Reply #1 on: December 22, 2017, 03:02:50 pm »
The cheapest answer is probably to  just use two scopes. Not so convenient, but you're always going to have single trigger source, which can be fed to both.
Day Job: Mostly LEDs
Online nctnico
« Reply #2 on: December 22, 2017, 04:56:28 pm »
Look for Yokogawa. They have several 8 channel models.
Offline tautech
« Reply #3 on: December 22, 2017, 07:41:43 pm »
Could a MSO with appropriately rated digital inputs meet your needs ?
What do you call HV ?  :-//
« Reply #4 on: December 22, 2017, 11:06:57 pm »
not actually looking for a new scope, as i've already solved the problem at hand.
I'm wondering about which scopes, old and new, come with more than 4 channels
how is yokogawa's software? never had the pleasure to play with one, besides lecroy rebadges
Online nctnico
« Reply #5 on: December 22, 2017, 11:18:39 pm »
The firmware you mean? I used to own a DL1740. Their oscilloscopes work well and offer many features but the older models are -well- old so their screens have a low resolution and the processing power isn't that great for stuff like FFT.
Online David Hess
  • DavidH
« Reply #6 on: December 23, 2017, 02:31:38 am »
The Tektronix 555 and 556 dual beam oscilloscopes could use a pair of 50 MHz 1A4 quad trace vertical plug-ins for 8 channels.  These oscilloscope could also display 4 channels plus the output of a spectrum analyser plug-in making them the first mixed domain oscilloscopes.  The Tektronix 5000 series mainframes could use a pair of 1 MHz 5A14N quad trace vertical plug-ins for 8 channels.  The Tektronix TLS216 "Logic Scope" is essentially a logic analyser with 16 x 8-bit 500 MHz 2 GS/s oscilloscope inputs.
When I needed a 4 channel DSO a couple years ago, I bought a pair of inexpensive Tektronix 2230s and stacked one on top of the other.
« Last Edit: December 23, 2017, 02:41:53 am by David Hess »
