Author Topic: Tektronix 2755P Analyzer  (Read 141 times)
Offline oe7dbhnewTopic starter
  • Country: at
    • HiDes technik & OE7DBH
« on: December 26, 2024, 01:20:35 pm »
Hi Guys
I have a thermal problem with my Tek2755P.
At some temperatures it works ok without any errors, and at other temperatures it gives the message:
Frequency control Failure        Tuning failure - 1ST LO   ( for span below 10MHz )
Error 7   Oscillator corrections are disabled
Has anyone had a similar problem and successfully solved it ?
Which plug-in card or component caused the error ?     .....Can anyone help ?
It's annoying when something fails during the measuring process (usually at around 20°C ambient temperature),
then I have to either cool it down or heat it up to make it work again.
Vy 73 de OE7DBH
Darko
