Author Topic: owon bench multimeter?  (Read 19503 times)
Offline chifridoTopic starter
  • Country: ar
« on: July 16, 2018, 01:49:33 am »
I'm looking for bench multimeter to be used mainly in low volts motor control circuits (dc servo drives, microcontrollers, etc)
In my country the test equipment is very expensive but I found that the local distributor of owon match the international price +tax and that makes the OWON XDM3041 4 1/2 my current choice.
There is no review, video, tear down or single writen word about this model and I have my doubs about the quality.
Does anybody own an owon bench multimeter? can you share your oppinion?
Main Features
- 4 inch 480 x 320 pixels high resolution LCD
- resolutions up to 4 1/2 digits
- reading rates up to 150 readings/s
- true RMS AC voltage / current measurement
- dual line display supported
- the change trend analysis accessible via special chart mode
- SCPI supported - remote control, and data-sharing
  possible via LAN, USB, RS232 port, and WiFi*
  * WiFi module is optional
- multi- IO interface: USB Device / Host, RS232, LAN, and ext.
  trigger input
http://lilliputweb.net/digital-oscilloscope/digital-multimeter/xdm-series/xdm3041.html
Offline radhaz
Re: owon bench multimeter?
« Reply #1 on: July 16, 2018, 03:06:47 am »
Not much of a review, but it's something at least.
The following users thanked this post: chifrido
Online coromonadalix
« Reply #2 on: July 16, 2018, 03:21:20 am »
Damn  Can't recall the brand  but seem to be a cloned version ??? specs seems okay to me,  price seems decent too, but an 4 1/2 display ???  not enough
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #3 on: July 16, 2018, 03:41:38 am »
They appear to be cloning the Siglent meters which inturn are cloning the Keysight meters  ::),  I wouldn't even bother with the Owon meter personally, their pricing down here is a complete joke when compared to other established brands. Pricing elsewhere overseas seems reasonable but $1100 down here for the 5 1/2 digit is just outright ludicrous.
  • Country: ar
« Reply #4 on: July 16, 2018, 03:44:09 am »
I managed to find another video that shows the boot process but no practical use case , I can't understand a word (persian language ?) and the site navigation was an adventure.
I can't embed the video, this is the link, I hope that Works between sessions:
https://as3.cdn.asset.aparat.com/aparat-video/d1232359794da2aafa32ff91d1542f9b6112810-1080p__16308.mp4
Offline tautech
« Reply #5 on: July 16, 2018, 03:48:28 am »
They appear to be cloning the Siglent meters .............
Actually no Muttley.
The front panel is quite different.
  • Cursed: 679 times
« Reply #6 on: July 16, 2018, 03:53:16 am »
From across the room they are somewhat similar in appearance you must admit.   ::) :P
  • Country: ar
« Reply #7 on: July 16, 2018, 03:56:36 am »
the price here is about 425 usd , for this money you can buy a Uni-t Ut804 at best  :-\
there is a 5 1/2 digits also, model xdm3051. I have no need for the higher resolution, I just want a multimeter to left powered on when I'm working.
I just found that there is a rebrand of owon called peaktech:
https://www.peaktech.de/productdetail/kategorie/digital---tischmultimeter/produkt/peaktech-4095.html
« Last Edit: July 16, 2018, 04:07:00 am by chifrido »
Offline radhaz
« Reply #8 on: July 16, 2018, 04:00:25 am »
Do you have other test equipment vendor sites in Argentina we can look at?
Offline tautech
« Reply #9 on: July 16, 2018, 04:05:02 am »
The 2 Siglent distributors, dunno what other brands they handle:
ELECTRO TOOLS ARGENTINA SRL
Address: HOLMBERG 3560, C.A.B.A
Tel: 54 11 4542-8312
ventas@electro-tools.com.ar
www.electro-tools.com.ar
TEMTEC S.A.
Address: Palestina 684 (C1182ADD) Ciudad Autónoma de Buenos Aires
Tel: (54.11) 4862-0062
Fax: (54.11) 4862-0882
ventas@temtecsa.com.ar
www.temtecsa.com.ar
@chifrido
See if SDM3045X meets your requirements and budget.
  • Country: ar
« Reply #10 on: July 16, 2018, 04:12:56 am »
TEMTEC S.A.
www.temtecsa.com.ar
@chifrido
there is severals distributors but the prices are out of my budget, for example
http://tienda.electrocomponentes.com/precios.php3?titulo=Multímetros%20Digitales%20de%20Banco&subrubro=101&rubro=10&expand=SI
the exchange rate is about 1 usd 30 ar$
the siglent sdm3045X is my choice but the local distributors do not stock it and a direct import is about 750 usd!!!!
Offline tautech
« Reply #11 on: July 16, 2018, 04:40:55 am »
Can you make a deposit and wait for their next shipment ? US price is $ 389.
https://www.siglentamerica.com/digital-multimeters/sdm3045x-digital-multimeter/
Offline nctnico
« Reply #12 on: July 16, 2018, 07:22:08 pm »
I know I'm repeating myself but look for a VC8145 if you need a no-nonsense DMM. It isn't expensive and basically is a 4.5 digit handheld DMM in a benchtop case with a mains power supply. The VC8145 is my daily use DMM even though I also have a high end DMM.
  • Country: ar
« Reply #13 on: July 16, 2018, 07:58:53 pm »
The local siglent distributor was not helpful  :-\
So the only real choice for me to own a siglent dmm is to buy it myself and brign it with me but there in no current plan to flight to the states (but currently is winter break here and a new dmm is totally a fair excuse right?)
The vc8145, buyed in aliexpress, will be about 240 usd and a waiting time of a month.
I can stomach the wait , the bad price, but I'm scared for the stories of "stuck autorange" at 8 vdc . Do the vc8145 has problems of this kind?
On wednesday I will be visit the owon distributor to test the dmm.
Offline nctnico
« Reply #14 on: July 16, 2018, 08:59:38 pm »
Not that I know of and I have mine since 2012.
« Reply #15 on: July 16, 2018, 09:08:36 pm »
the vc8145 (not the 8145B) at 80,000 count should be enough without hurting your wallet ?? and like some people report, they dont seem to have may problem with them,  just the backlight is not always on if i recall, but the display size should compensate.
On AliExpress there is a few at 120$ usd ???
Offline xbay
  • Country: tr
« Reply #16 on: August 15, 2018, 05:28:38 am »
Hi, have you been able to test the owon dmm? I am also interested with it. But there is no reviews.
Offline Mouse69
« Reply #17 on: March 16, 2020, 10:33:07 am »
Well here is my XDM3041, seems nicely made with space for a fan.
Mine was obviously dropped at some point (I recall the packaging was Ok), but the last shot shows a bent corner and one popped spot weld.  Still works and no external sign of damage.
I will try and do some tests and add the results.
Cut towards your chum, not towards your thumb
The following users thanked this post: coromonadalix, bd139, dophuc
Offline clane
« Reply #18 on: June 12, 2020, 10:29:53 am »
Hi Mouse69,
so what your impression on the Owon DMM you bought?
Is it fast at switch-on?
Thanks.
Offline Mouse69
« Reply #19 on: July 02, 2020, 05:34:30 pm »
It does seem to be fine, usable from switch on takes 6-7 seconds to get a DC voltage reading (defaults to this on startup)
Voltage DC, not warmed up for thirty minutes
1015290-0
Resistance, not warmed up for thirty minutes
1015286-1
And after thirty minutes, it's not changed.
« Last Edit: July 02, 2020, 05:57:16 pm by Mouse69 »
The following users thanked this post: clane
« Reply #20 on: July 02, 2020, 06:03:28 pm »
In the resistance pic, you're using Kelvin clips but the meter says it's in 2-wire mode.
Offline Mouse69
« Reply #21 on: July 08, 2020, 07:27:57 am »
Hi AVGresponding,
My bad, too busy taking the picture and most definitely not concentrating on the measurement (thanks for spotting my stupid mistake, I now have a chance to correct it  :-+ ).  I should have uploaded this picture:
1019050-0
Offline paulbt
« Reply #22 on: August 20, 2020, 12:28:04 pm »
Hello guys!
That Siglent bench DMM seems to be rebranded by RS PRO into model RSDM3055. See link below.
https://ro.rsdelivers.com/product/rs-pro/rsdm3055/rs-pro-rsdm3055-bench-digital-multimeter-10a-ac/1236465
Anyhow, is there any Owon bench DMM owner who encountered the same issue as this one presented in the video below?
"Simplicity is the ultimate sophistication."  Leonardo Da Vinci
Offline tautech
« Reply #23 on: August 20, 2020, 08:28:54 pm »
Yep, a few brands use Siglent as their OEM.
Some more in this thread:
https://www.eevblog.com/forum/chat/remember-when-siglents-logo-wasnt-ugly/
Offline Mouse69
« Reply #24 on: August 21, 2020, 09:24:53 am »
Hi Paulbt:
I'll try and recreate the issue in the video with my Owon and let you know.  I saw it ages ago but have not yet tripped over it when using the meter, that I've noticed  :-\
