Author Topic: Siglent SDS2000X Plus  (Read 1011028 times)
Offline KungFuJosh
  • TEAS is real.
Re: Siglent SDS2000X Plus
« Reply #4575 on: August 17, 2024, 06:17:57 pm »
Did you put the unzipped recovery files in the root of the USB stick?
Offline giovannirat
  • Country: at
« Reply #4576 on: August 17, 2024, 06:29:17 pm »
The file I've got was not zipped, it was a xxxx.ADS file and I've put this in the root of the USB stick.
Offline KungFuJosh
  • TEAS is real.
« Reply #4577 on: August 17, 2024, 06:39:41 pm »
ADS files are firmware files that get upgraded via the system menu in the scope.
If you're using a recovery package that operates during boot, it will not be an ADS file. The version I had was 4 files, none of which were ADS.
Offline giovannirat
  • Country: at
« Reply #4578 on: August 17, 2024, 06:52:14 pm »
That's interesting....
The file provided from Rob was "SDS2000X+_HELP_UPGRADE.ADS", on the other hand he mentioned in his instructions ""..place files..."
So you may be right and he sent the wrong link.
Thank you very much...
« Last Edit: August 17, 2024, 06:53:49 pm by giovannirat »
Online tautechTopic starter
« Reply #4579 on: August 17, 2024, 09:10:59 pm »
We have an updated recovery package now so I'll flick it to you soon.
The following users thanked this post: bingo600
Offline bingo600
« Reply #4580 on: August 18, 2024, 06:23:41 am »
Same here
@tautech
Will you resend to the full "BCC" list ?
« Last Edit: August 18, 2024, 06:30:36 am by bingo600 »
Offline Peter_O
« Reply #4581 on: August 18, 2024, 08:07:35 am »
There are two different patch sets:
One is the single ADS file.
The other is a set of files, none of which is ADS.
Tautech can say for sure what to use in your specific case.
« Reply #4582 on: August 18, 2024, 09:06:16 am »
This is the latest Uboot fix.  ;)
May or may not require latest FW install afterwards.....
Offline idolclub
« Reply #4583 on: August 28, 2024, 12:04:36 pm »
SDS2000X Plus Operating System_V5.4.0 (Release Date 08.27.24 )
Revision History
2024/08/21    5.4.0     Support time zone setting.
2020/04/17    5.0.0     Initial formal release.
Download:
https://siglentna.com/download/44461/?tmstv=1724836595
The following users thanked this post: KeBeNe, tautech, KungFuJosh, Deichgraf, mathstudi, Wrenches of Death, symphonystars
« Reply #4584 on: August 29, 2024, 12:44:08 am »
Revision History
Download:
Thanks, can also be found near the bottom of the page here:
https://int.siglent.com/download/firmwares/?ProId=53
Offline chostetler
« Reply #4585 on: August 30, 2024, 01:43:56 pm »
I saw a joke earlier in this thread about screen protectors and bubbles. Just received my scope from Saelig and I removed the screen film installed at the factory that had a red tab and said remove before use. However, my screen seems to have another film installed on it and in this one I have bubbles.
Is there a second protective film that needs to be removed or do I have an issue with my screen?
See photos. Scope is brand new just opened.
I received my in middle of 12/2022 and it had the same issue. At first I thought it’s defective display, but shortly I realized it’s 2nd layer.
I used toothpick to remove it.
Adding on to this with another new scope with the same issue. This one was from TEquipment. Attached picture is before I removed the film.  Maybe this is a factory film for the display that Siglent forgot to remove?  :-// Anyway, I just peeled it off like MarkusAJ suggested and now it looks great!
Offline Oberot
  • Country: ru
« Reply #4586 on: August 31, 2024, 05:02:31 am »
Hi all
After updating to a new OS, a problem appeared.
My scope is a localized version of Siglent for my country, All updates were installed from the official Siglent website and had no problems. https://www.siglenteu.com/service-and-support/firmware-software/digital-oscilloscopes/#sds2000x-plus
After the update OS, similar artifacts appeared in the scope menu, I also noticed some slowness in operation. How can I fix this?
« Reply #4587 on: August 31, 2024, 05:07:21 am »
The following users thanked this post: Badwater, Markus2801A, Oberot
Offline Oberot
  • Country: ru
« Reply #4588 on: August 31, 2024, 05:40:39 am »
Thanks tautech, everything worked
Offline core
« Reply #4589 on: October 30, 2024, 02:54:08 pm »
Can an SDS2000X Plus owner confirm if the latest firmware versions include the filtering function in Math?
I saw that the latest firmware version shows :
5. Fixed several bugs
d) Math: Filter sample rate adaption cannot work
Filter sample rate adaption functions seems to be specific for HD series, regarding the filtering operation.
Thanks !
« Reply #4590 on: October 31, 2024, 08:50:16 am »
Thanks !
Yes that might seem so however that's not entirely the case.
Strange indeed SDS2000X Plus does not offer sample rate adjustments so I have asked Siglent if SDS2000X Plus can support it.
The following users thanked this post: core, Deichgraf
Offline core
« Reply #4591 on: October 31, 2024, 10:52:35 am »
An update of the memory management control and possibly the introduction of filters could bring back the attention to this oscilloscope, still competitive in its price range.
The other functions are well implemented and not for everyone the 12 bit conversion is a must.
Offline Martin72
  • Testfield Technician
« Reply #4592 on: October 31, 2024, 01:41:00 pm »
I would be interested in that too, because there is no mention of it in the official revision history.
« Reply #4593 on: November 02, 2024, 05:44:44 pm »
HQ has indicated the memory management feature will be added in a FW update in 2025.
Agreed.
The following users thanked this post: KungFuJosh, Deichgraf, mathstudi, symphonystars
Offline core
« Reply #4594 on: November 02, 2024, 06:22:56 pm »
This is a really very good news !
Thanks !
Online cte
« Reply #4595 on: November 09, 2024, 06:30:54 pm »
Thanks !
I have 1.6.2R5 and I don't see any function named "Filter" in the menu (Math -> Function).
I don't know what this function does on the SDS2000X HD series but I guess this screenshot shows it in action.
