Author Topic: Brymen DMM Warranty and mods ??  (Read 1542 times)
Offline lordvader88Topic starter
« on: February 26, 2019, 02:20:00 am »
I have a Brymen BM869s and it's working fine, but the continuity buzzer is way too loud for just using in my room. I bought it new from ebay, maybe 2yrs ago. The guy sells a lot of them from Italy. Anyone know if there's any warranty on these from the factory ?
If not, or if it was almost up, I want to drop the volume on this a bit and make the backlight stay on longer. If I can get in there safely. These have 2 PCBs and lots of funny connections I think.
Offline coromonadalix
Re: Brymen DMM Warranty and mods ??
« Reply #1 on: February 26, 2019, 02:50:57 am »
This model use a dedicated chipset,  no specs have been found ..
« Reply #2 on: February 26, 2019, 03:06:40 am »
I'd hope that changing a resistor would lower the volume, and changing some capacitor would increase the light delay.
Offline radiolistener
  • Country: ua
« Reply #3 on: February 26, 2019, 03:09:01 am »
Does your DMM shows measurement change when you rubbing display with finger?
Offline ct1bxt
  • Country: pt
« Reply #4 on: February 26, 2019, 04:08:03 am »
Just made the test and no change on mine.
Rodrigo
  • Country: ua
« Reply #5 on: February 26, 2019, 07:00:11 am »
could you try this:
Select Voltage measurement, autorange and keep probes open.
Then slide your finger from left down corner to up.
Does it affect measurement result?
My 867 shows voltage jumps up to 0.03 V.
The same thing happens on R measurement, for 1 MOhm it may show even 0.3 MOhm at the moment of slide.
Is this ok?
I wrote to brymen support some time ago and they told me the following:
normal phenomenon. It is because the test current for 6MOhm range is less than around 0.125uA. For such kind of low current, the measurement may be easily affected by noise. If it gets 1Mohm reading while you do not touch plastic glass, then it should be no problem.
Also, when I slide finger from the left down corner to up, I see liquid crystal flashes on the display.
It seems, like high static electricity is induced on the other side of plastic glass.
May be there is need to use antistatic spray on the back side of the plastic glass?
Online indman
  • Country: by
« Reply #6 on: February 26, 2019, 07:34:10 am »
It is necessary to paste on the screen only a simple protective transparent film which protect displays of mobile phones. :)
« Last Edit: February 26, 2019, 07:36:14 am by indman »
Offline gearedbyby
  • Country: cn
« Reply #7 on: February 26, 2019, 09:49:43 am »
Connect the resistor to adjust the volume, design a repeatable trigger monostable control backlight
Offline Gyro
« Reply #8 on: February 26, 2019, 02:28:02 pm »
If it's a PCB mounted sounder (as opposed to a piezo disk glued to the back), then a simple self adhesive label stuck over the hole in the top usually provides about the right amount of sound attenuation.
Best Regards, Chris
Offline ct1bxt
  • Country: pt
« Reply #9 on: February 26, 2019, 07:12:29 pm »
in AC voltage, do the same hear, 0.034 volt.
DC voltage, no change.
Rodrigo
could you try this:
Is this ok?
