Products => Test Equipment => Topic started by: Elecmuso on May 09, 2024, 11:07:43 am
G'day
Have recently got myself a VEVOR SDS1022 and for the money it is great. But I cannot download to connected laptop. Have followed instructions to the letter and tried with 2 different notebooks with same result (one running Windows 11, the other windows 10). The green text in the lower right corner of the PC application display is displayed green indicating connection is there but trying to actually download data ends in an error.
Anyone had this and figured out a solution?
Anyone who has bought a Vevor scope, have you managed to download screen to a PC?
Well that was weird. Went to the same download area of the OWON site and downloaded it again - but it was a far more recent version. As though OWON had uploaded a new version today.
The old version I had was Version 2.2.2 (bulid:201908030943) which did not work.
The new version is Version 1.6.25.0 (bulid:202309191612) which does work.
Had another look at the website download functionality (https://www.owon.com.hk/download.asp?category=Digital%20Oscilloscope&series=SDS1000%20Series&model=&SortTag=\ (https://www.owon.com.hk/download.asp?category=Digital%20Oscilloscope&series=SDS1000%20Series&model=&SortTag=\)).
If you select 'SDS series' you will get the wrong version. Only by selecting 'SDS1000 series' will you download the correct version.
Does that even exist?
Isn't it an SDS1122?
You are half right (and yep my bad) - not a SDS1022 Nor SDS1122. It is a re-badged OWON SDS1102! Checked under the utility menu.
