Author Topic: Owon SDS200 series entry level bench scope (September 2024)  (Read 1454 times)
Offline tunkTopic starter
  • Country: no
« on: September 13, 2024, 02:06:20 pm »
- SDS210(S) 100 MHz, SDS215(S) 150 MHz, SDS220(S) 200 MHz
- 1 GS/s
- 2ns/div - 1000s/div
- 2mV/div - 10V/div
- max record length 20M
- "S" models have waveform generator:
  sine 25Mhz, ramp 1MHz, square/pulse/arbitrary 5MHz
- 7" screen, 480X800 pixels
https://eleshop.de/owon-sds210-oscilloscope.html
https://files.owon.com.cn/probook/SDS200_series_DSO_user_manual.pdf
Offline ataradov
    • Personal site
Re: Owon SDS200 series entry level bench scope (September 2024)
« Reply #1 on: September 13, 2024, 02:27:47 pm »
Looks like a barely updated SDS1102. But apart from the memory depth, it does not looks like much of an update. If they just want a newer SDS1102, then it is fine, I guess, but otherwise I don't see why bother.
It even uses the same plastic mold for the back cover as SDS1102. They just rearranged the front panel a bit, and made it worse, IMO.
I use SDS1102 as a main basic scope and it is quite good for what it is. It is silent (no fan at all) and boots instantly. The only thing that is really bad about it is the single trigger. Once it is triggered, re-triggering it is a lot of effort instead of a single button press. Realistically, if they fix just that I would really consider getting that. But I really doubt they did, the software looks pretty much the same.
« Last Edit: September 13, 2024, 02:38:45 pm by ataradov »
Alex
Offline viktor63
  • Country: ua
« Reply #2 on: November 22, 2024, 09:17:31 am »
There is a big advantage, it gives 1GSa/s on 2 channels simultaneously
Offline modoran
« Reply #3 on: November 22, 2024, 06:01:20 pm »
Only on 1kpoint memory ? It has 2Gsps ADC in it or it is just a trick ?
Offline viktor63
  • Country: ua
« Reply #4 on: November 23, 2024, 12:09:31 pm »
No information yet. I want to buy and see inside.
Online Aldo22
« Reply #5 on: November 23, 2024, 01:59:38 pm »
The trigger options are somewhat poor, according to the manual.
Only types: Edge and Video. No external trigger. Holdoff only works from 100 ns.
The competition from Hantek has many more types: “Edge,Pulse,Video,Slope,Overtime,Window,Pattern,Interval,Delay,UART,LIN,CAN,SPI,IIC”.
That seems a bit old-fashioned with the Owon.
Offline jasonRF
« Reply #6 on: November 24, 2024, 02:20:35 pm »
The manual says a 2K FFT, so a little underwhelming. The signal generator option look interesting, and the sds210s (100 MHz w/ siggen) is only $190ish on aliexpress.
I usually use a usb scope because it is quiet and I get a large screen, but if I bought a bench scope it would probably be something like the sds1102 or this newer model as long as it is fanless.
