Author Topic: OWON VDS1022I Quick Teardown (versus the Hantek 6022be)  (Read 121164 times)
Offline Gyro
Re: OWON VDS1022I Quick Teardown (versus the Hantek 6022be)
« Reply #575 on: February 26, 2020, 09:02:41 pm »
Nice wallpaper!  :-+
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline cosmin1
« Reply #576 on: February 26, 2020, 09:15:21 pm »
Thanks Gyro!  ;D
One more question. Can't see anywhere the background colour setting. I lost it?
« Last Edit: February 26, 2020, 09:18:29 pm by cosmin1 »
Offline Gyro
« Reply #577 on: February 26, 2020, 09:39:49 pm »
That's one you're going to have to wait for (maybe), I don't know if florentbr is planning to make that customizable too at some point. Owon used to offer 2 skins (Black and Blue) which he has removed in favour of individual colour settings, but they were both black background for the screen.
The black background is pretty much standard for scopes DSOs (apart from old mono LCD Tek ones and Picoscope). I think it give best trace contrast anyway, especially by the time you have measurements, cursors, math channel etc. up at the same time.
« Last Edit: February 26, 2020, 09:42:27 pm by Gyro »
Chris
Offline cosmin1
« Reply #578 on: February 27, 2020, 04:30:41 am »
Oh... i see.
I thought i read somewhere about changeable background too, but maybe i'm wrong.
Thanks again.
Offline indman
  • Country: by
« Reply #579 on: February 27, 2020, 05:46:53 am »
I suppose now i can uninstall the original 1.0.30, right?
I 'm glad you did well! :D
Uninstall the original version will also remove the USB driver from the system! So when you get your hardware Owon and plug it in, you 'll need to have those drivers in your system.
They can be installed separately if you save the USBDRV folder from the installed original 1.30 VDS_C2
I also suggest you delete your previous version installation messages from florentbr to avoid clogging unnecessary information with this topic. I will also delete my messages except one that contains a modified install-win.cmd.
Offline cosmin1
« Reply #580 on: March 12, 2020, 08:55:39 am »
I shouldn't have deleted the earlier posts...
I received the oscilloscope, insalled the manufacturer software and working fine.
But now i'm trying to install the florentbr's s/w on other laptop and i get this message. Installed Java but still can't install the s/w.
What else can i do?
« Last Edit: March 12, 2020, 09:12:10 am by cosmin1 »
Offline cosmin1
« Reply #581 on: March 16, 2020, 04:45:42 pm »
Now everything's installed right but the launcher is nowhere to find.  >:(
Offline Gyro
« Reply #582 on: March 16, 2020, 10:38:20 pm »
Try creating a shortcut with...
 %JAVA_HOME%\bin\javaw.exe -Djava.library.path="C:\Program Files\OwonVdsTiny\lib" -Duser.dir="%APPDATA%\OwonVdsTiny" -cp "C:\Program Files\OwonVdsTiny\jar\*" com.owon.vds.tiny.Main
(It should already be in your start menu - it says it created it)
P.S. Please try not to get angry about it. It's not as if the florentbr s/w something you're paying for, you already have the working product software!  :(
« Last Edit: March 16, 2020, 10:49:45 pm by Gyro »
Chris
Offline cosmin1
« Reply #583 on: March 17, 2020, 05:36:47 am »
I'm angry about my laptop, not about the software.
Will try to do that.
Offline Gyro
« Reply #584 on: March 17, 2020, 09:52:03 am »
Ah ok, it's perfectly normal to get annoyed at computers from time to time.  :)
I'm interested to know if the shortcut worked - you ought to find the one on your other computer to be identical (I think).
The only I thing I remember from your previous deleted installation posts was that it was important not to rename anything (folders etc.), after that, my memory fails me.
P.S. Reply #573 still contains the zip file from Indman which seemed to sort you out last time.
« Last Edit: March 17, 2020, 09:57:56 am by Gyro »
Chris
Offline cosmin1
« Reply #585 on: March 17, 2020, 10:07:00 am »
I use only install-win file from Indman.
After restart, the launcher shortcut appeared in Start menu.
But i can not change the colours. I set that blue colour but traces remain red/yellow.
« Last Edit: March 17, 2020, 10:23:32 am by cosmin1 »
Offline indman
  • Country: by
« Reply #586 on: March 17, 2020, 12:31:59 pm »
cosmin1
I explained everything to you in detail in my previous messages. You have a bad memory? Why do you need old useless messages that you and I have correctly deleted? You could simply copy an already installed shell from florentbr to a new computer. I see blue trace on your screenshot for X+Y mode. To select the color of individual trace, go to the Channels menu.
« Last Edit: March 17, 2020, 12:49:34 pm by indman »
Offline cosmin1
« Reply #587 on: March 18, 2020, 05:51:35 am »
You where right, but i just asked a decent question, no need to be rude.
I have many problems that i must take care of, and can't remember everything, especially since this is the first time i actually use this tool.
« Last Edit: March 18, 2020, 11:41:31 am by cosmin1 »
Offline common_ground
  • Country: cs
« Reply #588 on: March 27, 2020, 11:03:42 pm »
XY capability is actually not bad :
« Last Edit: March 27, 2020, 11:05:19 pm by common_ground »
The following users thanked this post: Gyro
