Author Topic: OWON VDS1022I Quick Teardown (versus the Hantek 6022be)  (Read 121117 times)
Offline camomille
Re: OWON VDS1022I Quick Teardown (versus the Hantek 6022be)
« Reply #400 on: November 11, 2019, 07:25:41 pm »
It's a lot better than me, you got them incorporated or do you want me to redo a new compilation?
Offline camomille
« Reply #401 on: November 11, 2019, 07:47:09 pm »
Version indman (photoshop)
sel1 / uns1 Black and Blue skin
https://ufile.io/p599w6ot
« Last Edit: November 12, 2019, 07:07:53 am by camomille »
Online indman
  • Country: by
« Reply #402 on: November 11, 2019, 08:25:58 pm »
camomille, thanks, I learned how to replace files with new ones in the JAR archive  :)
Now everything looks and works perfectly! Respect!
Offline camomille
« Reply #403 on: November 12, 2019, 07:10:22 am »
I changed my last link because there were some warnings at the compilation.
Online indman
  • Country: by
« Reply #404 on: November 12, 2019, 08:13:46 am »
Hi camomille!
Don 't think I 'm too brazen and a lot of things I want :palm:
I have one question about translating the interface into Russian language.
Is it possible to change messages in this window to Cyrillic?
Offline camomille
« Reply #405 on: November 12, 2019, 08:15:47 am »
For indman
For your reboot problem after a break, I do not know this problem because I do not use the VDS1022
but I think the track to follow would be rather the USB bus controllers with the power option try unchecked.
The following users thanked this post: indman
Offline camomille
« Reply #406 on: November 12, 2019, 08:19:06 am »
it does not bother me, I will look for the OFFLINE
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #407 on: November 12, 2019, 03:53:32 pm »
Yesterday I used a promotion on Aliexpress and pulled the trigger on a VDS1022I not in small part due to the developments done on this thread. It is pretty cool to see the work done by the community to make such neat unit be even more usable. Thank you!
Offline camomille
« Reply #408 on: November 12, 2019, 04:25:01 pm »
Hello,
Welcome rsjsouza, when you have your device, do not hesitate to ask for advice for the installation of the software.
For indman,
I have located the place where I stored the strings to display in the "TriggerStatus" window, but for now it returns an error message if I modify the text.
I hope to understand  :box:
Regards
Alain
The following users thanked this post: rsjsouza
Offline Gyro
« Reply #409 on: November 12, 2019, 07:57:17 pm »
@camomille:
Alain, you also need a green ball1.png for the Channel 1 trigger source... attached.
I've also attached the entire image folder for the JAR which includes all of the icons, including the above and your skin files, together with my revised Menu icons (Reply #376) modified for Green channel 1.
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline Gyro
« Reply #410 on: November 12, 2019, 08:11:12 pm »
The more, the merrier.
There's excellent work going on in the Hantek thread too but it's always going to be limited by its less advanced hardware than the Owon, particularly triggering.
« Last Edit: November 12, 2019, 09:01:46 pm by Gyro »
Chris
Offline rsjsouza
  • Eternally curious
« Reply #411 on: November 12, 2019, 10:00:44 pm »
Yes, the Hantek hardware is a crap shoot when compared to the Owon. Several reviews (including mikeselectricstuff) point to the honesty of Owon's hardware design and build.
Offline camomille
« Reply #412 on: November 13, 2019, 07:20:58 am »
Hello,
@Gyro
Thank you for the complete file "images" that allowed me to update my emulator because as you have noticed I am more technical than aesthetic and in addition you are much more talented than me.
@indman
I think I found how the program accesses the list of words "TriggerStatus", but it is necessary that eclipse accepts the Cyrillic in its instructions, it is necessary to modify 5 lines in Cyrillic from "Offline" to "Невсети"
confirm eng / russ conversion of "Offline"
Alain
Online indman
  • Country: by
« Reply #413 on: November 13, 2019, 08:31:54 am »
Hi camomille!
Are you implying that I will have to install and study eclipse? :)
Offline camomille
« Reply #414 on: November 13, 2019, 08:36:49 am »
@Gyro
Sorry but after exchanging image files, impossible to compile, error messages.
I reinstall my old version, it will be like before changing your personal pictures. |O
Alain
« Last Edit: November 13, 2019, 08:38:58 am by camomille »
Offline camomille
« Reply #415 on: November 13, 2019, 08:41:53 am »
@indman
no you do not have to install eclipse, it's me who must have incorporated the Cyrillic, I'm just asking you to confirm the text I wrote in Cyrillic. (post 413)
Only disadvantage (for me), your JAR version will be specific.
« Last Edit: November 13, 2019, 08:44:21 am by camomille »
Offline camomille
« Reply #416 on: November 13, 2019, 09:38:59 am »
@indman
Is good ?
« Last Edit: November 13, 2019, 09:42:29 am by camomille »
Offline Gyro
« Reply #417 on: November 13, 2019, 09:48:10 am »
@Gyro
Alain
Ha, that's the first time anyone has called me aesthetically talented!  :D
I'm sorry that the image folder caused you compilation errors. It works fine for me, but of course I am simply inserting it into the completed JAR file, so the compiler never sees it. I suppose it's possible that there is an image size error somewhere. I'm not sure if you could stomach such an ad-hoc method (adding after compilation) without sufficient explanation of the errors!
The ball1.png should at least cause you no compilation errors.
I hoped the complete image folder might save you some time. I have attached just the files related to my revised look (edited for green) individually, in case that helps.
If all else fails, indman knows how to substitute image files in the JAR now so he can do it at his leisure while you're looking at the 'Offline' status.
Chris
Online indman
  • Country: by
« Reply #418 on: November 13, 2019, 09:58:30 am »
@indman
Is good ?
Can you show me the entire message list in this trigger window? Do I understand correctly that the maximum length of a word in this window can be 7 characters?
I would translate "Offline" as "Нет сети" and "Auto" as "Авто"  :)
Offline camomille
« Reply #419 on: November 13, 2019, 10:01:53 am »
@Gyro
This is not too serious, because I had to reserve a precedent "workspace" complete.
I reinstated 2 "workspace" (ENG / RUSS) by inspiring me from my posts which serve me memory (that's why I always describe my modifications).
The following users thanked this post: Gyro
Offline camomille
« Reply #420 on: November 13, 2019, 10:34:47 am »
Here is the list of texts displayed in the window "Status"
Auto,Ready,Trg_d,Scan,Stop,Error,ReCfg,AutoSetting,Offline,USBFound,USBDrvErr,MachineNotSupport,Linking,Connect,Detect,Initialize
the program modify these texts :
"Trg_d" is convert in "Trig'd"
"Detect" is convert in "Match"
"Initialize" is convert in "Syncing"
"ReCfg" is convert in "ReSyncing"
"Autosetting" is convert in Autoset..."
It seems that the text modify width of the window (max 10 char !)
« Last Edit: November 13, 2019, 10:39:17 am by camomille »
Online indman
  • Country: by
« Reply #421 on: November 13, 2019, 10:46:22 am »
Oh my god, I didn 't think there would be that many messages! :palm:
Offline camomille
« Reply #422 on: November 13, 2019, 10:54:15 am »
there are surely some who are fugitive
Choose priorities because it's a lot of work.
Online indman
  • Country: by
« Reply #423 on: November 13, 2019, 11:40:27 am »
camomille,I will probably have to disturb my grey matter and learn to work with eclipse myself. I don 't want to bother you with my requests anymore.  :)
Offline camomille
« Reply #424 on: November 13, 2019, 01:47:04 pm »
@indman
Eclipse is only a tool that must be mastered, but the difficulty is to learn and understand the Java language.
Me, I do not know either, as I said before, it's enough to have time, gray matter and intuition.
In addition to these difficulties, you must constantly translate the notes into Chinese, understand in French (my language), convert to English (for all the world) and possibly incorporate Russian.
I do not speak English or Russian and it is the biggest difficulty because I spend a lot of time with the automatic translator and the checking so that it is almost comprehensible.
If you have time, gray matter and intuition (I think so), then I can give you a tutorial to install it and give you the source in a "workspace".
Otherwise I can make you the incorporation of your texts in Cyrillic, but we must limit you for an important reason, is that I must search all calls to this list for each word and copy / paste your word in Cyrillic, the problem is that if I forget one, at some point your program will be stoped without knowing why and I would not know why.
I will already try with the 2 words "Offline" and "Auto" that you have communicated to me in Cyrillic and you will test.
