Author Topic: OWON / VEVOR SDS1102 probe tips  (Read 360 times)
Offline ElecmusoTopic starter
« on: May 11, 2024, 12:34:12 am »
Is there a trick to removing the tips on the provided scope probes (OW3100)? I have tried with a lot of force to pull them off, any more force I feel could damage them. Is it just a case of pulling harder??!!
Offline thm_w
  • Non-expert
Re: OWON / VEVOR SDS1102 probe tips
« Reply #1 on: May 11, 2024, 12:42:34 am »
Some probe tips unscrew, some probe tips unclip.
Try to unscrew them first, if they just spin forever then they should unclip and you just need to pull a bit harder. They may get easier with use.
Fairly sure those are clip ones, you could check the manual too if there is one.
« Reply #2 on: May 11, 2024, 02:11:34 am »
Cheers. Already checked / searched the scope manual and the separate manual for the probes. Not mentioned anywhere!
Online Aldo22
« Reply #3 on: May 11, 2024, 09:34:30 am »
The first time they are often a bit tough.
I had my doubts too, but it worked with pulling. (But they were not from Owon)
Do they look like this? (From: https://www.amazon.de/OWON-HDS200-Handoszilloskop-Labor-Oszilloskope/dp/B0BX6KMYM2?th=1 )
Offline TizianoHV
    • My Website
« Reply #4 on: May 11, 2024, 10:43:29 am »
I have an OWON VDS1022I too. I had the same problem. If you want to remove the tip you have to pull a LOT.
After some time they started making bad contact and I had to repair them. So you should avoid remooving them often.
Now I just keep one with the tip and the other without.
« Reply #5 on: May 11, 2024, 01:39:45 pm »
Yep that's them. I will have to pull harder!
« Reply #6 on: May 12, 2024, 02:43:30 am »
Confirmed - probes now separated.
