Author Topic: Owon XDM3051 & Siglent SDM3055 bench multimeters: two of a kind?  (Read 2156 times)
Offline RobertPSTopic starter
Taking apart an Owon XDM3051, I was surprised to find an almost identical acquisition board compared to the Siglent SDM3055.
Was this some kind of joint development? Or did they shop at the same source? Who knows.
It's funny to see how Owon owonised it with some of their own components and their standard case and interface.
Owon puts the digital brain behind the front panel and uses a separate interface board. Siglent combines the two.
The voltage reference used is a MAX6325CSA. The fan is noisy and I will replace it or remove it.
The following users thanked this post: Markus2801A
Offline pfabri
Re: Owon XDM3051 & Siglent SDM3055 bench multimeters: two of a kind?
« Reply #1 on: January 16, 2023, 02:23:19 pm »
Did you go ahead with replacing/removing the fan? If so, I'd be really interested to hear about your findings. Thanks a lot!
