Author Topic: Panasonic VP-7722A : looking for Service Manual  (Read 4148 times)
Offline psykokTopic starter
« on: August 02, 2020, 08:15:43 pm »
I scored a Panasonic VP-7722A Audio Analyzer and I will need the service manual but was not able to found on internet.
would someone  have a copy of the service manual to share?
alex
Offline deadlylover
Re: Panasonic VP-7722A : looking for Service Manual
« Reply #1 on: August 03, 2020, 02:04:43 am »
Can you chuck me an email over PM later (throwaway fine), I have a copy somewhere, too big to attach here.
Was sourced from a few lads at a diy audio forum, make sure to create a post in the repair section on eevblog if you do any repair/mods, these units are quite rare but still reasonably capable today.  :P
Offline wichers
« Last Edit: June 15, 2022, 06:31:40 am by wichers »
The following users thanked this post: egonotto, Chris56000, TSCOLAN
Offline wichers
« Reply #3 on: August 27, 2020, 06:29:51 pm »
Bought one myself, mine is off needs a new 3.6v battery and caps are bad. I'm going to do a full recap so I OCRed the service manual and copied/corrected the capacitors values into an excel. This might be useful to others as well. Any suggestions or changes on capacitor values are welcome!
Kind regards,
Alexander
« Last Edit: August 27, 2020, 06:31:42 pm by wichers »
The following users thanked this post: Chris56000, TSCOLAN
Offline LoTech
« Reply #4 on: November 10, 2021, 06:08:25 am »
this is golden!
Thank you for sharing!!
Are you done with the recap and calibration? What did you use for the 3.6v battery?
Offline Raziel92
« Reply #5 on: January 31, 2022, 01:40:24 am »
Hello, I have the same audio analyzer and i have problems with tact switches, as I discovered they are integrated with leds, any info where I can order such switches? And details about them?
Offline USMC_Spike
« Reply #6 on: November 28, 2022, 12:45:49 am »
I have a VP-7722a, and some of the front panel push switches tend to stick and not function
properly until about 1/2 dozen or more times pressing and releasing.
any ideas on how to  clean/fix these before I attempt it?
Cheers,
USMC_Spike
