Author Topic: Pass/fail mask test on Rigol DS1000Z series  (Read 749 times)
Offline MitiTopic starter
« on: October 28, 2022, 04:35:30 pm »
I need to use a scope to check some waveforms in an automated test equipment. I was thinking of using a cheap DS1000 and do a pass/ fail test but I can’t find commands to load a mask that was created manually and saved on the external USB drive. Can DS1000 read from the external drive through a command or it is only manual?
Cheers,
Miti
Fear does not stop death, it stops life.
Offline Fungus
Re: Pass/fail mask test on Rigol DS1000Z series
« Reply #1 on: October 28, 2022, 04:51:07 pm »
I can't see any SCPI commands to load/save the masks.
It looks like they have to be loaded/saved manually.
Programming manual: MSO1000Z/DS1000Z_Programming Guide_EN.pdf
« Reply #2 on: October 28, 2022, 06:42:18 pm »
The SCPI command ':MASK:DATA' exists, it is described in the DS2000A programming manual. In the SCPI commands read from the DS1000z the command is present, only not documented. I don't have a DS1000Z anymore, so I can't test it.
Peter
Thanks Peter, it works like a charm!
Cheers,
Miti
