Hi folks,
perhaps for someone it`s useful. I played around with the OWON patch for the HDS3102M-N. In the folder of the patch there are some .bin files:
HDS3102M_N_FP_V2.01.bin
HDS3102M_N_OS_V1.1.6.bin
font10.13.bin
I thought that the patch (launcher.exe) would flash these files into the HDS3102M-N. So i played around and moved one file after another. And the patch process still works. Don`t know WHAT the patch really flashes?
I also made a test with a rs232 terminal.
I pluged in the RS232 cable in the COM-port of the HDS3102M-N AND the USB to the USB port. If you switch the unit on, you can read this in the terminal with 115200 8N1:
LILLIPUT
DSO TARGEY BOARD VER 1.0
2442loader-1G08.c(185)-Main
. . . 2442loader-1G08.c(1)-OS_ENTRY
2442loader-1G08.c(559)-OS_FILE_SIZE=1824440
So the question for me is what does that OWON Firmware Patch flash?
Are these bin files flashable images with the firmware for the device and how they can be flashed in the HDS3102M-N.?
