Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Philips PM2534 problem please help
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Philips PM2534 problem please help (Read 552 times)
tino van seggelen
Newbie
Country:
on:
July 16, 2020, 12:59:31 pm »
I have a Philips PM2534 Digital multimeter that only displays dashes.
I can operate it, change the range but it only displays dashes
Please help
Thanks in advance
Logged
tggzzz
Super Contributor
Country:
Re: Philips PM2534 problem please help
Reply #1 on:
July 16, 2020, 02:30:19 pm »
Did it ever work?
Look slowly and carefully at every component, for any obvious faults. Wiggle connectors, clean if necessary.
Get the service manual
https://www.google.com/search?q=philips+pm2534+service+manual
Check the PSU voltages and ripple. Replace capacitors if necessary. Follow the service diagnostics.
Logged
Glider pilot's aphorism: "there is no substitute for span". Retort: "There is a substitute: skill+imagination. But you can
buy
span".
Having fun
doing more, with less
PA0PBZ
Super Contributor
Country:
Reply #2 on:
July 16, 2020, 06:08:39 pm »
According to the users manual it does that when it is in single trigger mode and there is no result available yet.
Logged
PA1BS
Newbie
Country:
Reply #3 on:
October 08, 2020, 07:21:34 pm »
Do you have the indicators "M RNG" and "S TRG" on the bottom left of the display.
If you have then its in manual ranging mode with single trigger and waits for a trigger.
Press the AUT/MAN and then SINGLE buttons to leave this mode.
73, Ben
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Library
