Author Topic: Philips PM2534 problem please help  (Read 550 times)
Offline tino van seggelen
« on: July 16, 2020, 12:59:31 pm »
I have a Philips PM2534 Digital multimeter that only displays dashes.
I can operate it, change the range  but it only displays dashes
Please help
Thanks in advance
Online tggzzz
Re: Philips PM2534 problem please help
« Reply #1 on: July 16, 2020, 02:30:19 pm »
Did it ever work?
Look slowly and carefully at every component, for any obvious faults. Wiggle connectors, clean if necessary.
Get the service manual https://www.google.com/search?q=philips+pm2534+service+manual
Check the PSU voltages and ripple. Replace capacitors if necessary. Follow the service diagnostics.
Online PA0PBZ
« Reply #2 on: July 16, 2020, 06:08:39 pm »
According to the users manual it does that when it is in single trigger mode and there is no result available yet.
Offline PA1BS
« Reply #3 on: October 08, 2020, 07:21:34 pm »
Do you have the indicators "M RNG" and "S TRG" on the bottom left of the display.
If you have then its in manual ranging mode with single trigger and waits for a trigger.
Press the AUT/MAN  and then SINGLE buttons to leave this mode.
73, Ben
