I do not recommend this oscilloscope for two reasons:
- The storage CRT has a limited life and it is rare to find one in good condition. However, it can often still be used without the storage function if it is not too burnt.
- In Pm326X series, attenuators are different from most others Philips oscilloscopes.
Philips generally use reed relays to switch the resistances of the Y input, and that is very fine.
But here, this is not the case, there is no reed relay, it is contacts.
These attenuators give a lot of bad contact problems ... a true disaster ...
