Author Topic: Philips PM3350A/3352A/3355/3357/3365A/3367A/3375/3377  (Read 853 times)
Offline BK-TechTopic starter
« on: December 10, 2019, 06:13:53 pm »
Hello all.
I`m not good in Englisch, all so i make a Thread for all with this Problem.
My Oszi, very good, makes 1Sekunds Schschsch, then it goes even nothing.
No smoke because of default Parts. But it has smoked; between the High-Voltage-Circuit(green) and the Main-PCB-Board-Ground updown side!
See the Pictures at End. It`s a BG2000-641-505. I think it does not matter what kind of  BG2000-641, because inside is all the same. The last 3 Numbers are only for Conection-Cabel. I by 2x Kaskade for 1 in stock.  All so are the BJT: BUV26A, BC327 shortcut.
After changing the Parts all Funktion o.k.
Also i installed a 1A Fuse befor 230V Input.
Offline Yansi
  • STM32, STM8, AVR, 8051
Re: Philips PM3350A/3352A/3355/3357/3365A/3367A/3375/3377
« Reply #1 on: December 10, 2019, 06:16:33 pm »
Jeez... why the fuse addition? It already likely has one inside the IEC C13 connector housing and clearly it is a 1.6A slow blow.
« Reply #2 on: December 10, 2019, 07:51:23 pm »
There is not replacebel Fuse. Its a DIN-Conector with supress 230V in follow. Nothing Fuse!
« Reply #3 on: December 10, 2019, 07:55:09 pm »
I`m sorry .There is a Fuse-Box
Vorget it
