The PicoScope 6 GUI works pretty well for me on Windows, so yay. That said, their software API (PicoSDK) feels like it's straight out of the 90s and was a fair pain to use.
The scopes are great for portable debugging (e.g., automotive tech), and to some extent automated testing. However, I still like the physical knobs of a bench oscilloscope.
The only other comparable product I've used is the Digilent Analog Discovery 2. The PicoScope has better hardware, but the AD2's GUI is more comfortable to use.
Yeah I'm real tempted to try the AD2 instead, it seems a whole lot more professional overall
AD2 has more features built in software... But it is not more professional.
Picoscopes have proper scope front ends and construction and are used professionally by many thousands of professionals in industry.
AD2 is educational tool, it doesn't even have BNC connectors built in, you have to buy a breakout board.
Also it has only 2 input attenuation ranges. It has 16K SMps buffer which is very small that limits what it can do.
OTOH, it has 14 bit ADC/DACs and nice integration between the tools.
It is very useful tool nevertheless, if limitations don't bother you.
Fact that signals are connected to pin row connector might even be advantage if you want to integrate it into some "contraption" where you need more permanent connection, can assure signal levels are in optimum range and such..
I own Digital Discovery and use it all the time when I need pattern generation and logic analyser capability at the same time, for instance.. Unique tool for that. From specs:
Algorithmic pattern generator (no buffers used)
Counter and custom bus outputs
ROM logic for implementing user-defined Boolean functions and State Machines
Cross-triggering between Logic Analyzer, Pattern Generator, or external trigger
But limited too. To interface it to anything other than 3.3V logic you need to make voltage translators for instance... So useful but far from pro grade logic analyser/pattern gen with all kinds of interface options etc.
I would call Picoscope (both products and company) VERY professional. What they specify works as promised and better (longevity of support and products that last for decades). If you call them they WILL tell you up straight that MAC software is limited and that in order to use Pico you need to use Windows. You may not like it but they will tell you the truth. In 20 years of being their customer they never, ever, were anything but honest about what they products can and what they cannot do.
I call that professional above all.
