Author Topic: Picotest Injector Teardowns  (Read 2412 times)
Online Sighound36
Re: Picotest Injector Teardowns
« Reply #50 on: May 27, 2020, 03:47:17 pm »
Pretty respectable trace there for a 3Ghz bandwidth  :)
Ok not being an RF guy, so shoot me  :-DD, would it not be better to have less capacitors with a larger value? Or is this a fundamental issue with this portion of the design?
« Last Edit: May 27, 2020, 06:17:13 pm by Sighound36 »
Offline Jay_Diddy_B
« Reply #51 on: May 27, 2020, 06:11:30 pm »
Ok not being an RF guy, so shoot me  :-DD, would it not be better to have less capacitors with a larger value? Or is this a fundamental issue with this portion fot he design?
The capacitors I used are each 10uF 50V X5R 1210. The idea of such a high value is to get a low frequency -3dB point.
12 x 10uF / 2 = 60uF
R= 25 \$\Omega\$
F = 1/(2  x Pi x R x C) = 26.5 Hz
Regards,
Jay_Diddy_B
The following users thanked this post: Sighound36
Offline Jay_Diddy_B
« Reply #52 on: May 27, 2020, 06:17:21 pm »
Here are some TDR measurements  made with a Tektronix 11801 and SD24 sampling head.
The Bias injector was place between two lengths of semi-rigid 50 \$\Omega\$ cables:
From left to right
The 50 Ohm cable
the first 'wiggle' is the transition from the cable to the board, the SMA edge launch.
Then a short piece of 50 Ohm track.
two sections of 45 Ohms, about 25mm long, where the capacitors are
50 Ohm track
SMA connector
50 Ohm cable
I have marked the measured impedances on this drawing of the board assembly:
to raise the impedance where the capacitor are, I need to widen the gap between the traces and the ground plane.
Regards,
Jay_Diddy_B
« Last Edit: May 27, 2020, 06:24:30 pm by Jay_Diddy_B »
Online Sighound36
« Reply #53 on: May 27, 2020, 06:44:15 pm »
In a very crude way that is the situation I was attempting to elude to  :-[
Great stuff Jay, really do not know where you find the time but top man  8)
The following users thanked this post: fcb
Online 2N3055
  • Country: hr
« Reply #54 on: May 27, 2020, 10:06:06 pm »
Nice demonstration of usefulness of TDR..
Great work (as always!!) Jay..
Regards,
Sinisa
Online tv84
  • Country: pt
« Reply #55 on: May 27, 2020, 10:14:41 pm »
(Attachment Link)
Damn! This is an optimization of my suggested change!!!   :clap:  :clap:   Respect!
(I had removed it because, afterwards, I thought it was something irrelevant... )
« Last Edit: May 27, 2020, 10:17:27 pm by tv84 »
Offline sixtimesseven
  • EE
    • Flickr
« Reply #56 on: June 02, 2020, 04:08:22 pm »
Hello All,
I am not sure if this is the best place to start a discussion about PicoTest Line Injectors. They are useful tools, but tend to be on the expensive side. I wanted to upload what I have to be archived, and for those who wish to design their own or at least are interested in such topics. I hope this helps someone, somewhere.
Picotest J2120A Line Injector
Price: $525
BOM:
(4) Capacitors
  • C1||C2 = 35.7uF
  • C3||C4 = 1.98uF
(1) Resistor
  • 10k
(1) nMOS
J2120A front and rear pics attached.
Picotest J2130A DC Bias Injector
Price: $525
BOM:
(24) Capacitors
  • Parallel, Series network = 27uF
(1) Resistor
  • 10k
I do believe the equivalent network of the 24 caps is 27uF, I may wish to double check when I get a chance.
J2130A front and rear pics attached.
Ridley Injector Isolator Transformer
No specifications really. The manufacturer looks to be Avel Lingberg.
Model CA8518.
I hope this comes out clean, first time poster. Hell of a time with the pics.
*EDIT*
Added front picture of the J2120A.
Another nice one would be the "2180A" preamplifier to up the sensitivity of 8bit scopes. I wonder how they have done it in such a small package.
