Let me share a few measurements made on the prototype:
This is a picture of the prototype. It was milled on double sided FR4 PCB. The board is 100mm x 100mm
0 - 200MHzA DSA815-TG was used for the measurement. The setup was normalized with a BNC barrel connector.
The Bias tee is almost perfectly flat in the frequency range 0 - 200MHz.
This was confirmed using an HP3577A VNA
0 - 1.5GHzThe frequency range was widened to 1.5 GHz
There is a notch at 922MHz
After a little while I realized what was causing this.
I tested a BNC tee piece with an 8cm length of RG316 coax on one limb.
This is the result:
A notch at 625MHz
This notch is when the open length of the line is 1/4 of wavelength.
3 x 10E8 /625 x 10E6 = 48cm
1/4 wavelength = 12cm
velocity factor = 0.66
It kind of works out.
At 922MHz
wavelength = 3 x 10E8 / 922 x10E6 = 32cm
quarter wavelength = 8cm
Open circuit transmission lineThe resistor needs to be moved closer to the capacitors.
Regards,
Jay_Diddy_B
