Author Topic: Picotest Injector Teardowns  (Read 14811 times)
Offline Sighound36
Re: Picotest Injector Teardowns
« Reply #50 on: May 27, 2020, 03:47:17 pm »
Pretty respectable trace there for a 3Ghz bandwidth  :)
Ok not being an RF guy, so shoot me  :-DD, would it not be better to have less capacitors with a larger value? Or is this a fundamental issue with this portion of the design?
« Last Edit: May 27, 2020, 06:17:13 pm by Sighound36 »
Offline Jay_Diddy_B
« Reply #51 on: May 27, 2020, 06:11:30 pm »
Ok not being an RF guy, so shoot me  :-DD, would it not be better to have less capacitors with a larger value? Or is this a fundamental issue with this portion fot he design?
The capacitors I used are each 10uF 50V X5R 1210. The idea of such a high value is to get a low frequency -3dB point.
12 x 10uF / 2 = 60uF
R= 25 \$\Omega\$
F = 1/(2  x Pi x R x C) = 26.5 Hz
Regards,
Jay_Diddy_B
The following users thanked this post: 2N3055, Sighound36
Offline Jay_Diddy_B
« Reply #52 on: May 27, 2020, 06:17:21 pm »
Here are some TDR measurements  made with a Tektronix 11801 and SD24 sampling head.
The Bias injector was place between two lengths of semi-rigid 50 \$\Omega\$ cables:
From left to right
The 50 Ohm cable
the first 'wiggle' is the transition from the cable to the board, the SMA edge launch.
Then a short piece of 50 Ohm track.
two sections of 45 Ohms, about 25mm long, where the capacitors are
50 Ohm track
SMA connector
50 Ohm cable
I have marked the measured impedances on this drawing of the board assembly:
to raise the impedance where the capacitor are, I need to widen the gap between the traces and the ground plane.
Regards,
Jay_Diddy_B
« Last Edit: May 27, 2020, 06:24:30 pm by Jay_Diddy_B »
Offline Sighound36
« Reply #53 on: May 27, 2020, 06:44:15 pm »
In a very crude way that is the situation I was attempting to elude to  :-[
Great stuff Jay, really do not know where you find the time but top man  8)
The following users thanked this post: fcb
Offline 2N3055
  • Country: hr
« Reply #54 on: May 27, 2020, 10:06:06 pm »
Nice demonstration of usefulness of TDR..
Great work (as always!!) Jay..
Regards,
Sinisa
Offline tv84
  • Country: pt
« Reply #55 on: May 27, 2020, 10:14:41 pm »
(Attachment Link)
Damn! This is an optimization of my suggested change!!!   :clap:  :clap:   Respect!
(I had removed it because, afterwards, I thought it was something irrelevant... )
« Last Edit: May 27, 2020, 10:17:27 pm by tv84 »
Offline sixtimesseven
    • Flickr
« Reply #56 on: June 02, 2020, 04:08:22 pm »
Hello All,
I am not sure if this is the best place to start a discussion about PicoTest Line Injectors. They are useful tools, but tend to be on the expensive side. I wanted to upload what I have to be archived, and for those who wish to design their own or at least are interested in such topics. I hope this helps someone, somewhere.
Picotest J2120A Line Injector
Price: $525
BOM:
(4) Capacitors
  • C1||C2 = 35.7uF
  • C3||C4 = 1.98uF
(1) Resistor
  • 10k
(1) nMOS
J2120A front and rear pics attached.
Picotest J2130A DC Bias Injector
Price: $525
BOM:
(24) Capacitors
  • Parallel, Series network = 27uF
(1) Resistor
  • 10k
I do believe the equivalent network of the 24 caps is 27uF, I may wish to double check when I get a chance.
J2130A front and rear pics attached.
Ridley Injector Isolator Transformer
No specifications really. The manufacturer looks to be Avel Lingberg.
Model CA8518.
I hope this comes out clean, first time poster. Hell of a time with the pics.
*EDIT*
Added front picture of the J2120A.
Another nice one would be the "2180A" preamplifier to up the sensitivity of 8bit scopes. I wonder how they have done it in such a small package.
Offline corecode
« Reply #57 on: October 13, 2020, 10:02:14 am »
Could somebody explain what R1, R2, and C1 are being used for?  R2/C1 look like some sort of high frequency roll-off, but at a surprisingly high frequency.
Thanks!
LTspice model J2111A
« Last Edit: October 13, 2020, 10:04:55 am by corecode »
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #58 on: October 13, 2020, 01:01:30 pm »
Thanks!
R1, R2 and C1 are needed to prevent HF oscillations. Its more or less an output damper.
Whats also interesting is that the circuit has a dead zone around 0V. Even if the current monitor output will be OK,
the sunk current is not. The manual did not show this until a few months ago.
https://electronicprojectsforfun.wordpress.com/measuring-a-picotest-j2111a-current-injector/
« Last Edit: October 13, 2020, 01:09:44 pm by Wolfgang »
Offline corecode
« Reply #59 on: October 13, 2020, 01:11:41 pm »
Thanks for the quick answer.
I'm simulating a simplified circuit (no diodes, just sink from positive rail, different op amp (OPA358)) to understand the circuit and trade-offs.  However, I get peaking without C2, and with C2 I get a roll-off starting around 1MHz.  I guess I need to pick a different op amp?
Offline Wolfgang
« Reply #60 on: October 13, 2020, 03:25:09 pm »
Yeah, the output network is a compromise between 3dB frequency and stability. It needs to be matched to the OpAmp, thats correct.
And dont forget to simulate with all kinds of DUT PSU output impedances !
Offline corecode
« Reply #61 on: October 14, 2020, 08:39:40 am »
This is what I have come up with so far; crossed out components are not part of the simulation.
Looks like R13/C1 is to compensate possible L1 wiring inductance going to the DUT.
I will simulate various DUT impedance configurations next.
I wonder whether I should add an additional op amp to optionally boost the Pr1 output gain.  In general, I'm surprised by the signal level choices of the original design.
Offline corecode
« Reply #62 on: October 14, 2020, 01:08:04 pm »
Doesn't look too bad - of course the wiring to the DUT has a huge impact at the high frequencies.
Offline Wolfgang
« Reply #63 on: October 14, 2020, 01:40:02 pm »
When you look at my webpage about it you see that the PicoTest risetime claims are only realistic if there is less than 2-3cm of wire length between output and DUT. This will not be possible in a lot of cases. IMHO, it is smarter to live with reasonable bandwidths (0-5MHz) and better stability. Most injectors are used to determine the response of switching regulators. Their regulator loop bandwidth (not the switching frequency) is normally far below 100kHz, so a few MHz of injector bandwidth is good enough.
Offline corecode
« Reply #64 on: October 14, 2020, 02:08:23 pm »
I agree.  This was mostly an exercise to understand the limits of this approach.  It would be nice to observe most of the PDN performance at the supply vias of a chip.  I don't have a good FRA/VNA anyways, so this probably will be good enough to be used with my RTB2004's K36 option.
Latest design attached (qucs-s).  Maybe I'll get around to building it.
Offline Wolfgang
« Reply #65 on: October 14, 2020, 04:41:53 pm »
Testing PDNs is a tough test because of extremely low impedances here. Tests leads from your injector to the board are simply a no-no. Another challenge is that modern FPGAs draw 10s of amps at *very* low voltages. To make this move, you need to inject several Amps right at the DUT, asking for a very compact, solder-in solution for the injector and the same for the probe. This smells like copper-base PCBs, very modern switching MOSFETs in small cases, super-compact, all SMD designs, and so on. A funny challenge, but certainly not easy. An alternative for directly soldering the injector and the probes into the circuit is ultra-low inductance coax.
Offline Peter_Clements
« Reply #66 on: September 15, 2021, 02:33:58 pm »
Dear All,
I was wondering if anybody made it to a next stage and actually made a real PCB of a current injector and did some measurements.
@Wolfgang, your remarks are pertinent and I wondered if you had the time and courage to improve the design?
Looking forward to continue reading!
Peter
« Last Edit: September 15, 2021, 03:09:44 pm by Peter_Clements »
Offline Jay_Diddy_B
« Reply #67 on: September 15, 2021, 06:16:15 pm »
Peter_Clements,
Welcome to the forum.
I never built the circuit that I simulated in this thread. I did build and test a similar device in this thread:
https://www.eevblog.com/forum/projects/high-bandwidth-current-injector-for-impedance-measurements/
Regards,
Jay_Diddy_B
Offline Wolfgang
« Reply #68 on: September 15, 2021, 10:05:25 pm »
Hi Peter,
I confess I did not do a lot in the field of power supply impedance measurement lately. The reasons are:
- finished my PhD in the field of precision oscillators and this consumed a lot of time
- For the PSUs I have, my injectors worked fine. I mostly work with low noise linear stuff.
- Making superfast, high amperage injectors is only possible with a bag of special tricks and components.
  With my old eyes and shaky hands, I leave the development of these for the pros with appropriate manufacturing capabilities.
- If you have a specific question just ask. I try to answer as good is I know.
Best regards
  Wolfgang
« Reply #69 on: September 17, 2021, 07:17:23 am »
Thank you all for the information!
Offline gailulun
  • Country: cn
« Reply #70 on: March 08, 2024, 03:17:10 pm »
Thank you so much for the teardown information! Did you get pictures of other picotest modules?
Offline Wolfgang
« Reply #71 on: March 08, 2024, 03:58:47 pm »
Unfortunately no. I just have the injector. But I can only recommend to look inside their modules.
They are always good for some surprises :)
The following users thanked this post: gailulun
