I attempted to do a MEASUREMENT DATA LOGGER using RMS measurements on all 4 channels (see attached pictures). I set the timing to 0.1 seconds and attempted several logs and for some reason the logging, even though it started alright but the measurements would start randomly and sporadically not record the data. Longer the test lasted, the worse it got in 3 of the 4 channels. I also ran a SAMPLE DATA LOGGER and there was no missing data of any kind of distorted signal that I figured could be creating havoc with too much data at one time but that wasn't it. I even slowed down the sampling rate and remove two channels and but the problem still persists. Other attempts logging with the scope seem to have issues to see the data to record it on the far right of the screen. The readings kept going in and out showing "***" often, like when the voltage when up on the first 3 channels thing the 4th (green) channel by far did best and for the most part was consistent but it did cut out a few times. That lead was a different type and settings than the first 3.
I checked the lead connections and they seemed to been well connected to the loads. With all the missing information makes the data as a whole useless. Any ideas? It's a new meter. Hopefully it's not defective. Wondering if there's any thing I can do about it. Thank you in advance.
