Author Topic: USB to IR interface adapter for Fluke (and not only)  (Read 3944 times)
Offline serggioTopic starter
  • Country: ru
« on: May 17, 2016, 08:57:37 pm »
Today I finished assembling my USB - otpisolated UART converter for connecting Fluke measuring devices with IR interface to PC.
I have tested it on Fluke 289, but all Fluke meters with this communication interface can be connected to PC thru this adapter.
PCB was completely developed by me for using with FTDI FT232RL chip and TI open collector/drain or push pull comparators for logic level converting. Micro USB socket placed on front of board for connecting to PC. I decided to place IR emitting diode and photodiode on bottom side, but placement in parallel to PCB like in original converter also can be done. Either T1 or T1-3/4 packages diodes can be used as well.
« Last Edit: May 24, 2016, 07:36:57 am by serggio »
  • Country: ru
Re: USB - IR interface board for Fluke (and not only)
« Reply #1 on: May 19, 2016, 06:51:53 pm »
With small T1 diodes I find my IR interface adapter very useful with Fluke 287/289. The main idea was place board on top of device to have compact solution even for storing meter with connected adapter. To be honestly, I like it more than original Fluke IR189USB interface cable solution.  :P
some photos below:
Offline Dubbie
« Reply #2 on: May 19, 2016, 09:45:55 pm »
Very nice design there! Now you need to CNC a nice enclosure.
Sent from my phone using Tapatalk
Offline Helix70
  • VK4JNA
Re: USB to IR interface adapter for Fluke (and not only)
« Reply #3 on: May 24, 2016, 10:37:37 am »
Well done. What IR detector and transmitter leds did you use?
  • Country: ru
« Reply #4 on: May 24, 2016, 10:39:16 am »
I use Vishay TEFD4300 + TSAL4400.
?????????? ? ????? iPhone ????????? Tapatalk
Offline andyB2022
« Reply #5 on: April 11, 2023, 08:29:11 am »
Hi, any way I can receive gerber with the PCB please? :D
If not, could you tell me the distance between IR led's ? Thx.
Offline daisizhou
  • Country: cn
daisizhou#sina.com #=@
Offline sl1pkn07
« Reply #7 on: June 28, 2023, 06:28:10 pm »
Hello. this can work with older scopemeter 9x/105b series?
greetings
