Author Topic: Please recommend a scope (or other device) purely for audio testing.  (Read 13494 times)
Offline uktonyTopic starter
Re: Please recommend a scope (or other device) purely for audio testing.
« Reply #25 on: June 13, 2017, 08:32:54 am »
Thanks for all the replies and just to add a few points:
  • I already have a 30MHz Owon 'scope
  • I also have a Velleman PCSU200 'scope + waveform generator
(lousy software)
  • I am building preamps *not* power amps
  • I have a FocusRite Scarlett 2i2 (V2) USB interface (192kHz)
I realise that the Tsunami device has it's limitations, however as a basic measuring tool I reckon it'll suit my purpose in this instance.
I was looking for further insight into my measurements, as I've been finding that some of my designs show a rising response just at the top end of my sound card measurement ability ~85kHz which I though was odd (it's not the sound card or the measuring software).
Finally - my Owon 'scope has an FFT function which isn't bad, however apart from basic screen grabs, accessing the data from a PC results in a .bin file which only the Owon software can read.
Offline tggzzz
« Reply #26 on: June 13, 2017, 10:04:37 am »
@tggzzz: great, now tell him how to read data from an analog scope into a computer!  :palm:
You appear to have missed the word "preliminary". That may, or may not, be sufficient for his purposes.
Personally I would think that if he is interested in audio signals, then looking at MHz signals is only beneficial as a sanity check to verify there's nothing stupid happening. An analogue scope might be sufficient for that.
If not, then the Digilent Analog Discovery is probably a reasonable choice, but that is 10* more expensive and the OP has limited finances. I have no idea whether the AD would be sufficient for audiophile level testing.
« Last Edit: June 13, 2017, 10:07:18 am by tggzzz »
Offline Fungus
« Reply #27 on: June 13, 2017, 10:45:51 am »
If you live in a place where they're easy to find for $25.
Will your analog 'scope do frequency sweeps and bode plots? That's what audio work needs and the AD will do that nicely (much better than any 8-bit DSO).
« Last Edit: June 13, 2017, 10:47:25 am by Fungus »
« Reply #28 on: June 13, 2017, 12:38:56 pm »
This is a screenshot of a 5Hz to 1MHz on my Owon 'scope.
I enabled persistence to get a solid image.
Unfortunately there's no logarithmic option that I can find.
This sweep was generated by an AD9850 DDS generator that I control with an Arduino. I wrote a Windows program in vb.net to control it.
« Last Edit: July 13, 2023, 09:12:48 am by uktony »
Offline tggzzz
« Reply #29 on: June 13, 2017, 01:49:05 pm »
I know West Yorkshire is "oop t'north", but it isn't that remote :) There are several available on gumtree and fleabay!
While desirable, they might not be necessary. Given the OP can sweep a AD9850, he could generate a log frequency plot. Log amplitude would require a log amplifier.
Is 14-bit sufficient for the OP's puposes? Audiophiles might think not.
It is up to the OP to determine what else he could do with any money saved (oops: not spent).
Offline Fungus
« Reply #30 on: June 13, 2017, 02:33:28 pm »
The number of bits just sets the noise floor.
The noise floor demanded by audiophiles isn't the same as the noise floor needed for a piece of test gear.
Offline tggzzz
« Reply #31 on: June 13, 2017, 05:51:31 pm »
Plus, implicitly/indirectly, some other performance points, e.g. intermodulation and SFDR. Noise floor isn't the only parameter; see my .sig.
Which has the more stringent requirement depends on the tests being done and, in the case of audiophiles, the person :)
Offline Fungus
« Reply #32 on: June 13, 2017, 05:55:37 pm »
That's why I used 'demanded' and 'needed'.  ;)
Offline Loboscope
« Reply #33 on: June 13, 2017, 08:59:17 pm »
As everybody knows, audiophiles/audiophools are not interested in measurements and they will not make measurements. Because they have their "Golden Ears", and they are convinced, that these "Golden Ears" will even outperform the most recent Audio Precision gear so that ap will get jealous. Why bother about cost-intensive collected data of audio-gear when you have these "Golden Ears" and you will hear immediately the difference?  :palm:
Back to topic:
As I wrote before in other posts I always recommend the software "hpw-works" [http://www.hpw-works.com/] for measuring audio-gear. Together with a good/professional interface/sound-card you will be able to determine any relevant technical data of your audio-gear, reliable and with high precision - of course within the frequency-limits of your interface.
Offline Gary.M
« Reply #34 on: June 13, 2017, 09:33:02 pm »
Back to topic:
Stupid comments Lobo(Tomy)scope.
The op needs an Analogue Discovery as others have said. Look for one on ebay. You can use the network Analyzer to do what you want. Open loop bode plots?
Sent from my x600 using Tapatalk
Offline Gary.M
« Reply #35 on: June 13, 2017, 10:53:33 pm »
From HpW website:
Various signal analysis are performed like RMS, DR, THD, THD-N and more.
Also, RMAA is another great software for such purpose.
Soundcard based software won't do what the op said he wanted to do.
« Reply #36 on: June 14, 2017, 07:44:31 am »
From HpW website:
Indeed - I already ahve RMAA PRO and Audiotester. I also use Realtime Analyzer from here -> http://www.ymec.com/products/app/ra2.htm
All of the above are good software, but are still limited by sound card bandwidth of course.
HpW (very, very quirky and difficult to navigate) was evaluated, however that too would still be constrained by the limits of the sound card bandwidth.
Finding a used Analogue Discovery has proven to be difficult, as I guess people don't part with them in a hurry (even the first version).
The QA401 from QuantAsylum was also looked at, but again it's way over my budget.
I started this thread with the idea that someone might suggest something I've never heard of, or perhaps even a method / device I had not even considered.
But evidently I think I had considered all options!
« Reply #37 on: July 13, 2023, 09:33:49 am »
I was recently reminded of this thread so thought I should update it.
Six years later (six!) I have learnt a lot.
The Tsunami device I mentioned in my earlier posts turned out to be quite useless. I guess I was expecting too much.
A typical (affordable for a hobbyist!) digital scope is 8 bit or 12 bit, neither of which are much use for high resolution audiomeasurements.
I purchased a used Handyscope HS3 https://www.tiepie.com/en/usb-oscilloscope/handyscope-hs3 from 'TiePie' which has a 16 bit resolution mode with limited bandwidth (up to 200kHz from memory).
This has proven to be quite useful for tracking anomalies like oscillation etc.
But for measuring THD, SINAD and various other parameters, one really needs 24 bit, which means using a PC with sound card.
I purchased an Asus Xonar STX and using Wavespectra and Virtins Multi Instrument I am able to achieve some really useful measurements.
I created a dedicated page for audio test and measurement on my website for those interested. https://gtkc.net/audio-test-and-measurement-for-diy
I've attached a screenshot of a typical measurement.
