So far I have found a service guide which has a detailed block diagram. No component level schematics though. Then again you usually don't need a detailed diagram to fix something. Some clue as where to expect a certain signal is enough to start tracing the signal flow. When trying to fix something there are two rules:
- never say 'this can't be the cause of the problem'
- work systematically; after checking the power supply start at the beginning of a signal path
You still can be bitten by odd things like a power supply going into overvoltage protection because a fan isn't connected. It is not easy to find a fault in a perfectly working power supply
