Rigol DHO800 and DHO900 series are powered from USB-C PSU or power bank. But there is one thing that most of the electronic/electrical engineers/technicians will like to not think of or just forget to think of.
There is something called as a
earthing systems, which IMHO is not a fully proper name, because also applies to simplest devices powered from a single 1.5 V battery and fully enclosed. This is a just a surface of a safety knowledge of a safety in electrical devices. I think, most of people here, didn't spend hours on state exams about safety related to any electrical work.
Extra low voltage (ELV) PSU's like USB ones, creates another earthing system. Which is one of three: SELV, PELV and FELV. USB power supplies usually are SELV, at least in theory. In practice those are often between SELV and FELV, which means this is a huge safety hazard, especially if there is a tiny amount of moisture in the air. 70% air humidity can be a death trap - I know something about it from my personal experience.
Working with the oscilloscope and power grid it's not just simple as just buy first better probe or make it by Yourself. When scope is powered from a power supply that claims to be SELV, You either need to have fully secured PE-GND connection or to be absolutely sure about Your equipment and what are You doing. Bananas plugs with thin and Chinese made "copper", are very far from that.
Rigol supplied many of those scopes with a PSU's which are death traps. I bought DHO924S which was supplied with a Lite-On USB-C PSU. I tested it with a insulation tester (fancy ohm meter with higher voltage) and it failed pretty quickly. After I tear it down, reason was pretty obvious - it was designed to be very cheap, without safety in mind.
I heard in last couple month Rigol switched those two previous PSUs to a Delta brand. From my experience Delta makes very reliable and very safe power supplies and other things. But You never know if this is a genuine one or some fake.
Used insulation testers (another name: Riso meter) are very cheap. You can get one for like 80$, which can save Your or somebody else life. Not speaking of health, because burns and paralysis are not fun.
